hanra Into the laaaake Member 1,532 Member For: 17y 7m 1d Gender: Male Location: Nrth Qld Posted 02/11/07 10:21 PM Share Posted 02/11/07 10:21 PM When I cleaned my screen I had a look see under a pretty powerful microscope at work. It was still quite clogged. I then threw it in the ultrasonic cleaner, which helped a bit but there was still evidence of metal in the screen when looked at through a microscope. I would suggest replacing that screen every time instead of cleaning it. Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 17y 11m 8d Gender: Male Location: SW Sydney Posted 02/11/07 10:23 PM Share Posted 02/11/07 10:23 PM I wonder how quickly it gets blocked? and how much do the screens cost? might have to harrass the spare parts boys again! Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 22d Gender: Male Location: Perth, WA Posted 02/11/07 10:33 PM Author Share Posted 02/11/07 10:33 PM (edited) I wonder how quickly it gets blocked? and how much do the screens cost? might have to harrass the spare parts boys again!The screen can't be purchased separately, but only as part of the entire fitting.Cost last time was about $65.The biggest hassle is not the cost, but to actually get to it, and changing it without breaking it, as it has virtually no material thickness between the inside circlip holding the screen in place, and the outside thread for the oil pressure sensor (I've had 2 of these break on my car, one at delivery, and one during a change).I'm going to remove the screen and get a bigger inline filter (like mentioned by Luke earlier in this thread), which can be placed in a more service friendly location, and also has a much bigger surface area.I hope to not repeat this exercise Edited 02/11/07 10:34 PM by Ninka Link to comment Share on other sites More sharing options...
truongski Member 129 Member For: 17y 7m 13d Gender: Male Location: Brisbane Posted 03/11/07 07:19 AM Share Posted 03/11/07 07:19 AM sorry about the bad news. and glad that you have got is sorted so quickly. let us know how you proceed with oil supply screen filter. sounds like a good idea to relocate to a more accessible position and using better parts.good luck. Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 6m 23d Gender: Male Posted 03/11/07 10:36 AM Share Posted 03/11/07 10:36 AM that sounds good luke. 100$ is worth it imo to get easy access.how hard will it be to get a replacement bit of pipe for where the screen currently is, or will you just use the same fitting but without a screen in that bit. please let me know when you plan to have a go at it and I will come up and pass the spanners!not good to hear that after only 10k there is no oil coming down the line allan! that is a real worry.. not much would be getting through mine which is 80k old Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 9m 16d Gender: Male Posted 03/11/07 12:06 PM Share Posted 03/11/07 12:06 PM I've had turbos for over 15 years and never a failed turbo and I dont use filters on most turbo setups. Just high quality synthetic oil changed every 10K km and a clean engine to start off with. Get rid of the filter, its not really needed. Link to comment Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 6m 8d Gender: Male Location: The 8th Dimension Posted 03/11/07 12:07 PM Share Posted 03/11/07 12:07 PM Hideous looks like your onto a winner, keep us informed how it goes. Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 8m 21d Gender: Male Location: Brisbane Posted 03/11/07 10:41 PM Share Posted 03/11/07 10:41 PM Get rid of the filter, its not really needed.Not wishing to start a sh!t fight, but if the filter that's there is clogged up doesn't that indicate the need for a filter? I can't imagine these guys using crap oil and only changing it every 15thou kms. Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 22d Gender: Male Location: Perth, WA Posted 04/11/07 01:13 AM Author Share Posted 04/11/07 01:13 AM Not wishing to start a sh!t fight, but if the filter that's there is clogged up doesn't that indicate the need for a filter? I can't imagine these guys using crap oil and only changing it every 15thou kms.I guess there will always be small particles of impurities in the engine oil, but I doubt it would be sufficient to damage the bearing in the turbo, and a slightly noisy bearing is better than a total failure because the screen gets plugged.The problem is that the screen is way too small, and located in an area where servicing is really difficult, so an alternative filter would be a good insurance measure, though not an absolute necessity. Link to comment Share on other sites More sharing options...
Ghia Member 191 Member For: 22y 1m 7d Gender: Male Location: Aus.Vic.Melb Posted 04/11/07 06:55 AM Share Posted 04/11/07 06:55 AM The problem is that the screen is way too small, and located in an area where servicing is really difficult, so an alternative filter would be a good insurance measure, though not an absolute necessity.I'll be very interested to see what you boys come up with in terms up an alternative location for the screen...With all the threads (and now this one) relating to turbo failue I'm getting nervious. I'm probably just out of my league to change the current screen setup Link to comment Share on other sites More sharing options...
