Mike85 Member 13 Member For: 17y 9m 11d Gender: Male Location: Melbourne Posted 28/10/07 08:14 AM Share Posted 28/10/07 08:14 AM hey all,just wondering if anyone knows what this problem could be, yesterday was pretty hot so I had my AC going. Then I noticed water dropping down from the glovebox area onto the floor mat on the passenger side of the vehicle. (LHF) I turned the AC off and after a little bit the water stopped dropping. I also washed the car a little earlier that day as well. Any info would be much appreciated. Link to comment https://www.fordxr6turbo.com/forum/topic/39352-water-problem-under-glove-box/ Share on other sites More sharing options...
bloosted Cruise Control 1,383 Member For: 19y 6m 3d Gender: Male Location: Adelaide Posted 28/10/07 08:27 AM Share Posted 28/10/07 08:27 AM very common problem mate,the drain tube from your aircon is blocked easy fix Link to comment https://www.fordxr6turbo.com/forum/topic/39352-water-problem-under-glove-box/#findComment-589587 Share on other sites More sharing options...
stealthxr Donating Members 553 Member For: 19y 4m 2d Gender: Male Location: The Shire Sydney AUS Posted 28/10/07 12:00 PM Share Posted 28/10/07 12:00 PM Or it could be leaking heater core.... Link to comment https://www.fordxr6turbo.com/forum/topic/39352-water-problem-under-glove-box/#findComment-589676 Share on other sites More sharing options...
Mike85 Member 13 Member For: 17y 9m 11d Gender: Male Location: Melbourne Posted 29/10/07 12:07 AM Author Share Posted 29/10/07 12:07 AM so how would I unblock the drain tube for the AC?Where abouts is it? Link to comment https://www.fordxr6turbo.com/forum/topic/39352-water-problem-under-glove-box/#findComment-589787 Share on other sites More sharing options...
stealthxr Donating Members 553 Member For: 19y 4m 2d Gender: Male Location: The Shire Sydney AUS Posted 29/10/07 12:47 AM Share Posted 29/10/07 12:47 AM The drain hose sits directly above the gearbox to the left of it actually, it protrudes thru the tunnel a couple inches back from your firewall, use some coat hanger wire to unblock it. good luck with it Pete.. Link to comment https://www.fordxr6turbo.com/forum/topic/39352-water-problem-under-glove-box/#findComment-589799 Share on other sites More sharing options...
Mike85 Member 13 Member For: 17y 9m 11d Gender: Male Location: Melbourne Posted 29/10/07 05:13 AM Author Share Posted 29/10/07 05:13 AM cool, ill try that. thanks alot for the help Link to comment https://www.fordxr6turbo.com/forum/topic/39352-water-problem-under-glove-box/#findComment-589888 Share on other sites More sharing options...
Mike85 Member 13 Member For: 17y 9m 11d Gender: Male Location: Melbourne Posted 07/11/07 08:45 AM Author Share Posted 07/11/07 08:45 AM yeah, you guys were right. stuck the coat hanger in the draintube and the water pissed out. thanks again guys. Link to comment https://www.fordxr6turbo.com/forum/topic/39352-water-problem-under-glove-box/#findComment-593170 Share on other sites More sharing options...
Boony_1981 Member 32 Member For: 18y 3m 17d Location: Townsville Posted 08/11/07 01:28 AM Share Posted 08/11/07 01:28 AM How about water coming out from the centre console and dripping down to the drivers feet?I went for a 2 hour drive and had the air-con on the whole way. About an hour into the drive I took a hard left hand corner and a river of water came from the centre console and dripped out onto my feet for about 15 seconds and then stopped. I got out and checked that the air-con drain was not blocked because it was dripping out a steady rate onto the road. Same thing happened on the 2 hour drive back home too.Any suggestions?....Other than not taking hard left hand corners anymore and not using the air-con anymore! Link to comment https://www.fordxr6turbo.com/forum/topic/39352-water-problem-under-glove-box/#findComment-593391 Share on other sites More sharing options...
ENVI.BA Member 146 Member For: 16y 5m 29d Gender: Male Location: 2155 Posted 07/03/10 05:32 AM Share Posted 07/03/10 05:32 AM ive got the same problem at the moment Link to comment https://www.fordxr6turbo.com/forum/topic/39352-water-problem-under-glove-box/#findComment-988616 Share on other sites More sharing options...
