Water Problem Under Glove Box
Mike85
  • Member For: 17y 5m 10d
hey all,
just wondering if anyone knows what this problem could be, yesterday was pretty hot so I had my AC going. Then I noticed water dropping down from the glovebox area onto the floor mat on the passenger side of the vehicle. (LHF)
I turned the AC off and after a little bit the water stopped dropping. I also washed the car a little earlier that day as well.
Any info would be much appreciated.
  • Member For: 19y 1d
The drain hose sits directly above the gearbox to the left of it actually, it protrudes thru the tunnel a couple inches back from your firewall, use some coat hanger wire to unblock it.
good luck with it
Pete..
  • 2 weeks later...
  • Member For: 17y 11m 16d
How about water coming out from the centre console and dripping down to the drivers feet?
I went for a 2 hour drive and had the air-con on the whole way. About an hour into the drive I took a hard left hand corner and a river of water came from the centre console and dripped out onto my feet for about 15 seconds and then stopped. I got out and checked that the air-con drain was not blocked because it was dripping out a steady rate onto the road. Same thing happened on the 2 hour drive back home too.
Any suggestions?....Other than not taking hard left hand corners anymore and not using the air-con anymore! :shocked:
  • 2 years later...
