New Blow-off Valve
f-wolf
  • Member For: 17y 9m 6d
Just found this in the USA.
Is it possible to get one here in Australia? If yes how much and from where.
This unit will restore lost power and will hold more boost pressure than the stock units for added performance. This Aluminum spring loaded Piston-Cylinder valve is a proven design that wil last not like the original plastic Bosch diaphragm valve that warps in less than a year causing a lot of power loss. Replacement is a 5 minute job
Features Include:
CNC Precision Machined Billet Aluminum
Internal Components Lubricated with High Temperature Synthetic Grease for a Lifetime of Trouble Free Use
Dual Viton O-Rings for an Unmatched Seal Around the Piston
Direct Replacement for OEM Valve
Will Not Leak Boost and Eliminates the "Honking" Sound
"Recovers" Quicker for Better Boost Response
Flow Bench Tested to flow at least 10% More CFM of air than the OEM Valve
[insert Link]
* New model (in Picture) different from the one pictured in this video. The new model has 6 bolts and not a twist on.
  • Forged Member
  • Member For: 17y 11m 24d
you can get the kompact from Autobahn, but its a bit more than that, I can't remember how much I paid for mine, check the postage rates getting it from the US if that's what you end up doing
  • Member For: 17y 3m 4d
I was thinking of buying a BOV how easy/hard is it to install? mind you I haven't had a descent look at a new BOV to see how it would be installed?
