  • Inactive Members
  • Member For: 17y 7m 21d
I to am going to do the replacement braided lines and pads and fluid when talking to people in the industry they told me to stay away from the silicone fluid they said it was crap several recomend Syn 4 penrite dot 4 dont know if this helps at all
  • CNUTOX
  • Member For: 22y 5m 11d
When I had my rotors changed, the silly f*ckers pushed on the pedal as they were bleeding, and did something in reverse order, I can't renember, :banghead: , but they f*cked the master cylinder. Handed me back the car, assured everything is a-ok, I go to stop at the rounabout, and the pedal hit the floor, nothing. I rang FORD and they said don't drive it, we will tow it to the dealership. Result, I new master cylinder under warranty.
Velluto a question for you... When your braking, if you pump the brake pedal 3-4 times, does it come good for that stop, then fade away again? If it does this, I am pretty sure your MC is fukt. :crybaby:
Goodluck dude. :spoton:
  • Member For: 18y 1m 23d
Re " Braided Lines - Huge Disappointment "
I got them on my T, Front and Rear. No Problems @ all.
Unless you got a leak @ the " Braided Lines " I would say the Problem is elsewhere.
So your " Braided Lines - Huge Disappointment " is not what I would have used !
