  • Member For: 21y 11m 22d
had to go down the road today to pick the kids up,I gave it a little on the way,got there,kids get in,go to leave-NO POWER- the throttle(acceleration system) fault indicator on the dash was on-NOT HAPPY JAN- Iturned it off for a second and the light went off so I drove it home.Seemed ok,has anyone had this problem?,should I take it to dealer?I need help!!!!
https://www.fordxr6turbo.com/forum/topic/3926-my-new-xr6t-broke-down/
Guest ratboy_ledg
  • Guests
buddy you should take it to a dealer but I suspect they will return it to you saying could not fault on day on your way sir...... you will have to wait till it fails or the problem occurs when the ford service techie faults it but I would be straight there... :hmmm:
  • Used to work at the Ford Proving Ground!
  • Member For: 22y 2m 9d
  ratboy_ledg said:
buddy you should take it to a dealer but I suspect they will return it to you saying could not fault on day on your way sir...... you will have to wait till it fails or the problem occurs when the ford service techie faults it but I would be straight there... :thumbsup:
that's a silly coment. if a light comes on the dash or you have a problem that's computer related get it looked at as it will log a code in the computer and it tells the Ford mechanic exactly what the problem is. easy fixed! Its not all smoke and mirrors you know. some things are straight foward!
down to the dealer. change calibration or parts and then on your way.
  • Member For: 22y 1m 3d
  chrislak said:
Mine stalled a couple of times when it was new and hasn't done it since.
yes it happenned to me at 500k's but hasn't done it again :thumbsup: now at 7500k's
  • I don't suffer from insanity; I enjoy every minute of it
  • Member For: 22y 4m 16d
  FuriousXR said:
Mine stalled a few times when idilling took it back to ford and they replaced the hole throttle body
Mine has never actually stalled, but it has come close on a number of occasions
  • SLOJAM, Gone but not forgotten
  • Member For: 22y 6m 26d
mine also stalled a couple of times PRIOR to the 3000k service. I believe they did something to the ECU and now done 11000k with no problems.
rainy - See your dealer if only for peace of mind
Kvntoday - relax, read the forum and get a "feel" for others experiences. IMO By far most owners are more than happy and there have been no major mechanical failures to date (that I am aware of).
Guest xr6 turbo
  • Guests
I;ve had my XRT go into "Limp" mode on a trip up north. I took it to the Dealer and they found that the VCT module had misbehaved therefore putting the car into "Limp" mode. They flashed the ECU with updated software and I havn't had a problem since.
