What Size Fitting Do I Need?
toddyp
  • Member For: 19y 7m 17d
Just a quick question.
I need a fitting similar to that below, but am unsure what size I need. They are available to fit 1.25inch, 1.5inch and 1.75 inch hoses. I need it for the bottom radiator hose on a Ba Falcon.
So does anybody know which size is needed for the bottom radiator hose?
  • Member For: 17y 6m 20d
I got a 36mm fitting for a water temp gauge sender unit fitted to the top hose. The 36 mm was a tight fit.
1.75" = 44.45mm, 1.5" = 38.10mm, 1.25" = 31.75mm.
So in your case I be looking @ 1.5" / 38.10mm.
I just measured the OD of the bottom hose, not much difference between top and bottom hose.
Edited by f-wolf
