  • Member For: 18y 11m 20d
  turbotrana said:
you can run a cooler thermostat but depending on the tuning of cold start parameters you might still be on a little choke (cold fuel enrichment) at 80 degrees. . You really need to check with someone who has access to the tuning tables. eg at 80deg you might have +3% fuel being added phasing out to 0% at 85deg
The ECU switches to the base fuel table (normal operating table) @ 120 f although standard it adds timing up to 180f
