Monza Install
hanra
  • Into the laaaake
  • Member For: 17y 8m 8d
Ive had this I/C here for a month or so now. Was considering installing it when my typhoon bar goes on. Then ive also gotta plug this CAPA box in and get a tune.....
Ive read the wogs install instructions and other posts instructions
Does anyone have any pics of the alignment of the brackets once installed. Im sure ill work it out. But would be nice to do it right the first time.
So yeah, some pics of the I/C installed without the bumper would be good. Or pics of the brackets would be even better.
Cheers.
  • Replies 34
Posted Images
  • Into the laaaake
I think mine should go on ok. (should).... I dont have the lower powersteering cooler and mine is a MKI. Ill take pics of mine once its on so everyone can see the bracket alignment.
  • Mmmmm......BOOST
  • Member For: 17y 9m 25d
no the original brackets are left off wich I was'nt real happy about because they have the rubber mounts the monza ones don't
  • Mad Scientist
  • Member For: 20y 2m 24d
the red circles are where the brackets are mounted, I had to drill two holes on the passenger side
(note that the bottom passenger side you cannot actually see the bolt, as it on the other side of the crash bar)
  • Mad Scientist
Oh ok, I always thought it used the original bracketry as well.
nah you use the ones provided with the cooler, u use the factory holes on the drivers side, and drill two new ones on the passenger side :roflmbo:
  • Mmmmm......BOOST
I have the ba mk1 and didn't have to drill any holes just took a lot of patience to line them all up hav'n someone to help you hold things helps a lot
