nang3 12" member Donating Members 2,107 Member For: 20y Location: Perth WA Posted 20/10/07 04:32 AM Share Posted 20/10/07 04:32 AM yeh I bet we get stitched up bigtime with pricing !! we always suffer and its farked !! you can get AMG mercs for half the price in the states, so this will be no different..I reckon this new GTR will be a ball tearer - all the previous models have been amazing compared to other cars produced in the same year Link to comment https://www.fordxr6turbo.com/forum/topic/39069-new-gtr-breaks-covers/page/7/#findComment-586563 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 1m 30d Gender: Male Location: Brisbane Posted 20/10/07 09:22 AM Share Posted 20/10/07 09:22 AM They are forecasting that the aussie dollar will get higher in the first half of next year - should help with the pricing (if the bastards are kind enough to pass on their savings) Link to comment https://www.fordxr6turbo.com/forum/topic/39069-new-gtr-breaks-covers/page/7/#findComment-586633 Share on other sites More sharing options...
nang3 12" member Donating Members 2,107 Member For: 20y Location: Perth WA Posted 20/10/07 09:57 AM Share Posted 20/10/07 09:57 AM tab said: They are forecasting that the aussie dollar will get higher in the first half of next year - should help with the pricing (if the bastards are kind enough to pass on their savings)nope, I bet they use the climbing dollar just to increase their profit margin rather than reduce the cost of the car.US$80k is only about AUS$88-89k at the moment, I would buy one in a heartbeat at that price !! I cant think of much for those dollars that would match it... Link to comment https://www.fordxr6turbo.com/forum/topic/39069-new-gtr-breaks-covers/page/7/#findComment-586652 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 1m 30d Gender: Male Location: Brisbane Posted 20/10/07 10:47 AM Share Posted 20/10/07 10:47 AM Yeah I was speaking theoretically.... Obviously the local demand will be high enough for them to charge whatever they want. Link to comment https://www.fordxr6turbo.com/forum/topic/39069-new-gtr-breaks-covers/page/7/#findComment-586670 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 4m 10d Gender: Male Location: Sydney Posted 24/10/07 07:08 AM Share Posted 24/10/07 07:08 AM Specifications Engine • VR-series twin-turbocharged 3.8-litre V6. • 353kw @ 6,800 rpm. 588 Nm torque @ 3,200–5,200 rpm.• Dual overhead camshafts with variable intake-valve timing. • Cast aluminum cylinder block with high-endurance/low-friction plasma-sprayed bores. • IHI twin turbochargers, one per cylinder bank. • Pressurized lubrication system with thermostatically controlled cooling. Drivetrain • ATTESA ET-S All-Wheel Drive (AWD) with independent rear-mounted transaxle integrating transmission, differential and AWD transfer case. • Rigid, lightweight carbon-composite driveshaft between engine and transaxle. • Electronic traction control plus 1.5-way mechanically locking rear differential. • Vehicle Dynamics Control (VDC-R) with three driver-selectable settings: Normal (for daily driving, controls brakes and engine output), R-Mode (for ultimate performance, utilizes AWD torque distribution for additional vehicle stability) and Off (driver does not want the help of the system). • Hill Start Assist prevents rollback when starting on an incline. DisclaimerVDC-R cannot prevent accidents due to abrupt steering, carelessness, or dangerous driving techniques. Always drive safely. Transmission • 6-speed Dual Clutch Transmission with three driver-selectable modes: Normal (for maximum smoothness and efficiency), Snow (for gentler starting and shifting on slippery surfaces), and R mode (for maximum performance with fastest shifts). • Fully automatic shifting or full sequential manual control via gearshift or steering wheel-mounted paddle shifters. • Dual clutch design changes gears in less than 0.5 second (0.2 second in R mode). • Downshift Rev Matching (DRM). • Predictive pre-shift control (in R mode) based on throttle position, vehicle speed, braking and other information. Wheels and Tires • 20 x 9.5" (front) and 20 x 10.5" (rear) super-lightweight forged-aluminum wheels with Gunmetal Gray finish. • Exclusively developed nitrogen-filled Bridgestone® RE070A high-capacity run-flat summer tires, 255/40R20 front and 285/35R20 rear. • Tire Pressure Monitoring System (TPMS).• Optional exclusively developed nitrogen-filled Dunlop® run-flat all-season tires, 255/40R20 front and 285/35R20 rear (includes Bright Silver wheels). Brakes • Brembo® 4-wheel disc brakes with 4-wheel Antilock Braking System (ABS), Brake Assist, Electronic Brakeforce Distribution and Preview Braking. • Two-piece floating-rotor 15-inch front and rear discs with diamond-pattern internal ventilation. • 6-piston front/4-piston rear monoblock calipers. Steering • Rack-and-pinion steering with vehicle-speed-sensitive power assist. • 2.6 steering-wheel turns lock-to-lock. Suspension • 4-wheel independent suspension with Bilstein® DampTronic system with three driver-selectable modes: Normal/Sport (for automatic electronic control of damping), Comfort (for maximum ride comfort), and R mode (engages maximum damping rate for high-performance cornering). • Electronically controlled variable-rate shock absorbers. High-accuracy progressive-rate coil springs. • Front double-wishbone/rear multi-link configuration with aluminum members and rigid aluminum subframes. • Hollow front and rear stabilizer bars. Body/Chassis • Exclusive Premium Midship platform with jig-welded hybrid unibody. • Aluminum hood, trunk and door skins. Die-cast aluminum door structures. • Carbon-reinforced front crossmember/radiator support. Back to Top Standard Features Exterior • Wide-beam headlights with High Intensity Discharge (HID) low beams. • LED taillights and brake lights.• Dual heated power mirrors.• Flush-mounted aluminum door handles.• Body-color rear spoiler with integrated center high-mounted stop light.• UV-reducing tinted glass. Audio/Navigation/Performance Monitor • Digital Bose® audio system with AM/FM/in-dash 6-CD changer and 11 speakers including dual subwoofers.• HDD Music Box system, including hard drive with 9.4 GB for audio storage. • MP3, WMA and DVD audio capable. In-dash Compact Flash card reader.• HDD-based GPS navigation with touch screen.• Driver-configurable performance monitor, developed with Sony® Polyphony, with graphical readouts of vehicle data and driving data displayed on a total of 11 screens.• 7-inch WVGA high-resolution color-LCD display for audio, navigation and performance monitor. Interior • Automatic Temperature Control (ATC).• Electronic analog instrument cluster with multi-function trip computer and digital gear indicator.• Power front windows with one-touch auto-up/down feature.• Intelligent Key system with pushbutton start. Power door locks.• Cruise control.• Tilt/telescoping steering column.• Bluetooth® Hands-free phone system with voice recognition. Seating/Appointments • Leather upholstered front seats with perforated Alcantara inserts.• 8-way power front seats with entry/exit switch for rear-seat passengers.• Driver-shaped bucket seat.• Dual individual rear seats.• Heated front seats.• Leather-wrapped steering wheel and shift knob.• Drilled aluminum pedals. Safety/Security • Nissan Advanced Air Bag System (AABS) with dual-stage supplemental front air bags, seat belt sensors and occupant-classification sensor.• Driver and front-passenger side-impact supplemental air bags and roof-mounted curtain supplemental air bags.• Front seat belts with pretensioners and load limiters.• Nissan Vehicle Immobilizer System.• Vehicle Security System. Link to comment https://www.fordxr6turbo.com/forum/topic/39069-new-gtr-breaks-covers/page/7/#findComment-588021 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 4m 10d Gender: Male Location: Sydney Posted 24/10/07 10:26 AM Share Posted 24/10/07 10:26 AM Click on GTR Detail > Movie (top of screen) and the movie should playGTR Record run at the Nurburgring Link to comment https://www.fordxr6turbo.com/forum/topic/39069-new-gtr-breaks-covers/page/7/#findComment-588124 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 4m 10d Gender: Male Location: Sydney Posted 24/10/07 10:53 AM Share Posted 24/10/07 10:53 AM Go Auto's Motorshow review Link to comment https://www.fordxr6turbo.com/forum/topic/39069-new-gtr-breaks-covers/page/7/#findComment-588157 Share on other sites More sharing options...
SHOWDOWN BACK SLOWER THEN EVER! Member 706 Member For: 17y 11m 21d Gender: Male Location: Sydney Posted 24/10/07 11:01 AM Share Posted 24/10/07 11:01 AM Mal if I haven't said it before... I'll say it now... YOU THE MAN!!! That will look hot in Dark Grey or Black. Ozzie Link to comment https://www.fordxr6turbo.com/forum/topic/39069-new-gtr-breaks-covers/page/7/#findComment-588164 Share on other sites More sharing options...
2MUCHKW Member 350 Member For: 19y 2m 5d Posted 24/10/07 04:04 PM Share Posted 24/10/07 04:04 PM Wheels say its gonna be $160,000 Wonder what the depreciation will be on a $160K Nissan after 12 mths of ownership? :wacko: Link to comment https://www.fordxr6turbo.com/forum/topic/39069-new-gtr-breaks-covers/page/7/#findComment-588246 Share on other sites More sharing options...
f-wolf Member 897 Member For: 18y 1m 30d Gender: Male Location: ACT Posted 24/10/07 10:12 PM Share Posted 24/10/07 10:12 PM 2MUCHKW said: Wheels say its gonna be $160,000 Wonder what the depreciation will be on a $160K Nissan after 12 mths of ownership? :wacko:Super value supercar: Ballistic Nissan could be priced here from $150,000.Nissan?s long-awaited GT-R to offer Porsche 911 Turbo performance at half the price TOKYO 24 October 2007FORGET its awesome 310km/h top speed, ballistic 0-100km/h sprint time of 3.6 seconds and Porsche 911 Turbo-equalling 353kW of power ? 150,000 is the number in Australian dollars that may yet excite GT-R fans the most.This is the price that Nissan Australia is hoping to stick on the twin-turbocharged V6 all-wheel drive four-seater R35-series GT-R coupe when it arrives here in the first quarter of 2009 ? or even late next year if all goes well.Over four years in engineering gestation, the production car known in Australia as ?Godzilla? was finally unveiled today at the Tokyo motor show, six years after it first appeared as the GT-R Concept at the same event, and two years since that initial show car morphed into the GT-R Proto concept.Japanese buyers will pay around $A78,000 when sales commence in December.The latest version delivers 588Nm of torque (32Nm short of the Porsche) and can lap Germany?s hallowed Nurburgring Nordschliffe racetrack in seven minutes and 30 seconds, pulling g-forces of 2.0 (side) and 1.8 (braking).In fact, Nissan defines a supercar as a vehicle with a power-to-weight ratio of 4kg/hp (0.75kW), having a top speed capability on a public road of over 300km/h and being able to lap the Nurburgring in eight minutes or less.Despite the massive capabilities on offer, Nissan has dubbed the R35 GT-R ? an all-new and bespoke vehicle that has the job of being its technological showcase for future models ? as a year-round proposition that can be driven anytime, anywhere, and by anybody.The company says that the GT-R?s docility and accessibility partly lies in the GT-R?s debut GR6 dual-clutch six-speed gearbox, which features a three-mode automatic mode as well as a two-mode manual mode. Gears can be selected with paddles or the gearshift and, in racing mode, can shift up or down in 0.2 seconds.Nissan?s engineers claim they had the idea for the gearbox before the Volkswagen Group launched the conceptually similar DSG dual-clutch transmission in 2002. It was developed in collaboration with Borg Warner.GR6 works in conjunction with Nissan?s ATTESA all-wheel drive system that now features an electro-magnetic clutch instead of a hydraulic one, a heat exchanger for reduced heat build-up and lower friction, a mechanical limited slip differential, and dry-sump lubrication.Torque is usually apportioned 100 per cent to the rear wheels, but up to 50 per cent can be diverted to the front wheels.The engine is Nissan?s all-new VR38 60-degree angle V6 of 3799cc capacity, a compression ratio of 9:1 and a bore/stroke of 95.5 x 88.4.Its 353kW peaks at 6400rpm, with the rev limiter cutting in at 7000rpm, and the 588Nm maximum torque is available between 3200rpm and 5200rpm.The official Japanese combined cycle fuel-consumption average is 12.2L/100km and the engine rates Ultra Low-Emission Vehicle (ULEV) status in the United States.Its integrated twin-turbocharged induction system features electronic boost pressure control and a secondary air-injection system for cleaner emissions and improved fuel economy.One senior GT-R engineer revealed that discarding the decades-old tradition of inline six-cylinder engines for the more common V6 design was not a point of debate because the V6 was better-suited to achieving the car's performance, packaging and weight distribution targets.Suspension is by an independent double wishbone set-up at the front, and a multi-link arrangement at the rear. It includes Bilstein electronically adjustable dampers for improved ride characteristics.Brakes are by Brembo, and have big drilled floating rotors, aluminium monoblock calipers (six-piston at the front, four-piston at the rear) and a large-diameter master cylinder.Runflat tyres are used, and are 225/40ZRF20 97Y at the front and 285/35ZRF20 100Y at the back, fitted to lightweight 20-inch alloy wheels.The GT-R will only come as a two-door coupe.Designer Masato Taguchi pointed to the front mudguard?s ?aero grade fender? blister and feature line ? which also contains a vent housing designed to help with airflow and brake cooling ? as his favourite styling detail on the car.Other high points for the designer include the rear-quarter view and the horizontal crease in the C-pillar, which is designed to help the flow of converging airflow at speed for aerodynamic optimisation.Aluminium is employed for the bootlid, bonnet, front suspension strut and seatbelt housings, door panels and some underbody bracing brackets while carbon fibre is used for the front underbody sheeting area.Kerb weight is 1740kg, front/rear weight distribution is about 53/47 and aerodynamic drag is rated at a competitive 0.27Cd.The driver-orientated interior features high-up eye-line placement for all instrument and monitor displays.The latter is a multi-function unit that has a vast array of vehicular motion-related technical data inspired ? and created ? by Sony?s Polyphony group that is behind the Gran Turismo PlayStation phenomenon. With today?s GT-R, it seems that life is imitating art that is imitating life?However, pimply teenagers will obviously not be the target customer group, nor will the wealthy banker, lawyer and advertising agency types that drive 911s.Instead, Nissan is counting on the Baby Boomer generation: aged over 50, and over the superficiality of brand image.Nissan has introduced for the first time an engine assembly process that is overseen by one specialised technician working in an environmentally controlled ?clean room? to ensure highest-possible quality and control.The company has also sought to improve build quality, not allowing even a 0.1mm panel gap discrepancy, and uses chip-resistant paint finishes, while a higher level of customer service is also being used to make GT-R buyers feel special. Link to comment https://www.fordxr6turbo.com/forum/topic/39069-new-gtr-breaks-covers/page/7/#findComment-588266 Share on other sites More sharing options...
