  • Member For: 18y 1m 8d
when the car is on ramps how much oil should you expect at the oil filter?
I want to screw it off to get at the engine oil sensor, will I need to do an oil change lol?
is the oil level below the filter? or will it run out if I screw it off .. cheers...
https://www.fordxr6turbo.com/forum/topic/39045-how-much-oil/
  • No boost, no bottle, just my foot on the throttle!
  • Member For: 21y 4m 6d
While I have never tried this, I would expect under a litre will come out.
If your car has done 5,000km do an oil change
https://www.fordxr6turbo.com/forum/topic/39045-how-much-oil/#findComment-584972
  • 4 weeks later...
  • Member For: 17y 7m 12d
that's correct about 1/2L will come out, no oil should flow out, unless the car is running, cause it is after the oil pump.
https://www.fordxr6turbo.com/forum/topic/39045-how-much-oil/#findComment-594377
