How Much Oil
BF_Turbo
  • Member For: 17y 9m 6d
when the car is on ramps how much oil should you expect at the oil filter?
I want to screw it off to get at the engine oil sensor, will I need to do an oil change lol?
is the oil level below the filter? or will it run out if I screw it off .. cheers...
  • Member For: 21y 4d
While I have never tried this, I would expect under a litre will come out.
If your car has done 5,000km do an oil change
  • 4 weeks later...
  • Member For: 17y 3m 10d
that's correct about 1/2L will come out, no oil should flow out, unless the car is running, cause it is after the oil pump.
