  • Sucker
  • Moderating Team
  • Member For: 21y 13d
  senna_T said:
this was touched on in the cobra thread, the reason it will be the same is because they can't build a 290 and 302 beside each other, if they did it would be a costly exercise and parts could be mixed up by the monkeys on the line
What parts are different?
Would just be a different tune wouldn't it? :stirthepot:
  • Forged Member
  • Member For: 18y 3m 1d
it has different cams, valves and valve sprigns tab, also a higher comp. ratio - 10.5:1 upto 10.8:1
Considering the differences are so small, it would be easy to mix up, even if they were in different coloured boxes, as they do between XR8 260 and the GT 290/302
  • Forged Member
yeah all that, but you have to remember, they can't break the euro3 emissions regs, so they have to do a bit so its effiecient
  • Member For: 21y 7m 4d
  tab said:
Oh righto....all that for a measly 12kw!!!
Yeh doesn't sound right does it... I believe it'll be more. Just need to get a few Cobras down the strip or on the dyno to tell... :roflmbo:
Oh by the way the 302 will be fitted to the Force8/GT/GTP/P/SP IF they have any left after production of all the Cobras. Only 50 are estimated to be left around to be thrown in the mainstream FPVs.
Read http://carpoint.com.au/car-review/2832105.aspx for more.
  • Forged Member
the engines will be used in normal fpvs, 50 would be about right, as there is only about 2 months worth of BF left before orion, the 302 engines will be built all the way up to feburary as the production for cobra is scheduled til then, FPV need to keep customers interested in the rest of the FPV line up, hence the 302 in them all
  • Member For: 22y 6m 28d
Yep ... strange but true. Just an edit would see more than 12kW eh. But lets say you wanted to "trial" some internal bits needed to produce a 351kW model in the near future?
