  • Member For: 17y 10m 25d
I was back in perth last week and got a few mods done and the big girl custom tuned. (ba mk2 ute 6speed manual). Overall real happy with the power it made, although the arc is not that smooth im sure it will be fixed the next time im back ( I had to take the car back as I was flying back out for work)
it made 326rwkw but was tuned back to 314rwkw @ 15psi..
mods are :
Xforce 3 1/2 Inch system
Xforce 4 Inch Dump
Xforce 3 1/2 Inch Cat
Valve springs
2nd Cai
Injectors
Fuel pump
custom tuned..
oh and the mal wood option 3 clutch...
next time im down it should be getting the process west stage 2 kit with cai and back on the dyno she goes to get rid of the dip in the graph...
https://www.fordxr6turbo.com/forum/topic/38983-had-me-t-tuned-finally/
  Felix said:
Congrats!!
What was causing the dip?
Felix
the boys reckon the heat was causing the power to dip (sumthing like the comp was taking timing out because the old girl was getting red hot.. the process west stage 2 kit is next and will go back on the dyno and wont leave the shop until the arc has no dip... theyre confident it will go and so am I... hpefully! :spoton:
Congratualations chopnu great result mate dont be too fussed about the dip it seems like its a digital dyno and sometimes they can be very sensetive when they draw the graph and at times you will see graphs like this,the old analouge dyno,s will draw a smoother graph,put up on a analouge dyno and you will get a smoother graph.The problem wont be in the tune,seems like a good power curve the boys at BPT done a great job.Enjoy your ride.
  Trough Lolly said:
so that result is with the STOCK cooler??????!?!?
yea mate its running the stock cooler.. the pw cooler should be ordered hopefully in the next 3 - 4 weeks before I get back to perth.. :crybaby:
  • Member For: 20y 8m 3d
  chopnu said:
yea mate its running the stock cooler.. the pw cooler should be ordered hopefully in the next 3 - 4 weeks before I get back to perth.. :stirthepot:
why the hell did you even bother getting it tuned till you had the cooler??
the tuner should of had the brains to tell u to wait it off a week or so!
