groper Member 611 Member For: 18y 3m 19d Posted 03/10/07 01:00 PM Share Posted 03/10/07 01:00 PM (edited) he sounds nizpro style, so it will be a 044 pump...edit;- do option A except ditch the pump and go for the cat instead...so that's, injectors, springs, cat... a cooler would top it off, even if its just a $300 wogcooler...edit again; somone needs to make a big fat stick at the top "ALL you need to know about modififying the xr6t" in it, a list of mods with the power range at which point the car reaches a restriction and the mod to overcome it.... all the way up to 500+rwkw and then we wouldnt have so many people asking the same questions... Edited 03/10/07 01:07 PM by groper Link to comment https://www.fordxr6turbo.com/forum/topic/38781-whats-more-important-to-do-next/page/2/#findComment-581072 Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 1m 29d Posted 03/10/07 01:13 PM Share Posted 03/10/07 01:13 PM groper said: he sounds nizpro style, so it will be a 044 pump...edit;- do option A except ditch the pump and go for the cat instead...I would be more inlined to do a fuel pump. The stock fuel pumps pressure relief valve opens way to easy and you can end up leaning out with boost pressures above 12-13psi, so you could end up shooting yourself in the foot when chasing power.As far as fuel pump goes, 044 is a external type fuel pump to be run in conjunction with a surge tank. The common intank upgrade most people go for is the Walbro GSS-341. Link to comment https://www.fordxr6turbo.com/forum/topic/38781-whats-more-important-to-do-next/page/2/#findComment-581077 Share on other sites More sharing options...
dlakers3peat Member 67 Member For: 18y 2m 11d Gender: Male Location: sydney Posted 03/10/07 01:17 PM Author Share Posted 03/10/07 01:17 PM groper said: he sounds nizpro style, so it will be a 044 pump...edit;- do option A except ditch the pump and go for the cat instead...so that's, injectors, springs, cat... a cooler would top it off, even if its just a $300 wogcooler...edit again; somone needs to make a big fat stick at the top "ALL you need to know about modififying the xr6t" in it, a list of mods with the power range at which point the car reaches a restriction and the mod to overcome it.... all the way up to 500+rwkw and then we wouldnt have so many people asking the same questions...I agree with you that would help. by the way no one forces you to answer these topics so please have a little patience with people who just need some advice. thanks Link to comment https://www.fordxr6turbo.com/forum/topic/38781-whats-more-important-to-do-next/page/2/#findComment-581079 Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 1m 29d Posted 03/10/07 01:23 PM Share Posted 03/10/07 01:23 PM dlakers3peat said: I agree with you that would help. by the way no one forces you to answer these topics so please have a little patience with people who just need some advice. thanksThe only problem with doing that is that there is more than one way to skin a cat. Link to comment https://www.fordxr6turbo.com/forum/topic/38781-whats-more-important-to-do-next/page/2/#findComment-581083 Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 10m 13d Gender: Male Location: The 8th Dimension Posted 03/10/07 01:31 PM Share Posted 03/10/07 01:31 PM Also every car is different, there is no hard and fast rules on max power for any of parts on these cars. Link to comment https://www.fordxr6turbo.com/forum/topic/38781-whats-more-important-to-do-next/page/2/#findComment-581086 Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 6m 6d Gender: Male Location: Dé·jà vu Posted 03/10/07 03:28 PM Share Posted 03/10/07 03:28 PM There already is one in a way.....http://www.fordxr6turbo.com/forum/index.php?showtopic=38174 Link to comment https://www.fordxr6turbo.com/forum/topic/38781-whats-more-important-to-do-next/page/2/#findComment-581111 Share on other sites More sharing options...
Gavin.K Member 288 Member For: 19y 11m 7d Gender: Male Location: sydney Posted 03/10/07 10:32 PM Share Posted 03/10/07 10:32 PM Option a and also get your self a good tuner whome has the runs on the board nudge nudge. Link to comment https://www.fordxr6turbo.com/forum/topic/38781-whats-more-important-to-do-next/page/2/#findComment-581136 Share on other sites More sharing options...
