  • Member For: 20y 10m 5d
Sounds like your making good progress.
If your not already doing so, it would be a good idea to start keeping a log of discussions with all parties including the ACCC, including the ones you have already had, as best as you can recolect. Arbitrators, if it should come to that, love that sh!t :blink:
  • Member For: 17y 6m 28d
hey guys
well fairly good news
adrian from DBA said my rotors were still okay, they only machined .3mm off the brakes which is okay.
he said the heat spots were just cause by residue on the rotors burned by the brake pads.
but you guys were right. the EBC pads are too hard for the rotors
so I went back to ABS with all the info I had gathered and explained to him what I wanted, and he has agreed to replace the brake pads with whatever I wanted,
so what pads do you guys think will be good for the DBA rotors the slotted ones just below the 4000 series ones??
I dont want any like the EBC ones which need to be too hot to work properly cause I never get a chance to get them up to that tempreture. and probably not ones that are too hard that just chew up the rotors...
thanks again guys
Pete
  • www.australianflag.org.au
  • Member For: 19y 8m 29d
Its not that the pads are to hard on the rotors, its because the leak resin and it burns onto the rotors. The same thing happened to me years ago, DBA and EBC dont mix.
Scotty
thanks for the help guys...
I spoke to ABS and they are gonna replace the pads for something more suited, cause the rotors are fine which im happy with..
im told ferodo formulas are best suited for me but ABS wont use them so I have to find something else...
im thinking either bendix ultimate or bendix SRTs
does any1 else have any ideas???
thanks again for the help :-)
