Hitting The Rev Limiter...!
Steffche
  • Member For: 17y 6m 19d
Hi guys,
Just been taking my brand new XR6T for a spin, and I hit the rev limiter a couple of times because I either changed gear from 1st to 2nd too late, and on one occasion I went the wrong way on the damn gear shift (6 speed auto).
Is it bad? Have I perhaps caused any long term damage? Risked losing power output from the engine?
OR...is the rev limiter safe and hence why they have it..?
Im stressing out a bit...any thoughts???
Everything sounds fine..no noises or anything...Im jst stressing...
  • Replies 21
  • Member For: 17y 10m 9d
Don't worry about it.
It takes about 2 months with the 6spd auto, to stop hitting your face on the windscreen.
Trick is to only put your hand on the shifter when you need to change.
Embarassing hitting 1st gear at 70K's
  • Member For: 18y 9m 13d
Think again guys before saying its alright to smack of the rev limiter. You are putting your already fragile oil pump gears under much strain when doing so. Much like leaving the traction control on. So in short try to avoid it as much as you can. :w00t2:
Think again guys before saying its alright to smack of the rev limiter. You are putting your already fragile oil pump gears under much strain when doing so. Much like leaving the traction control on. So in short try to avoid it as much as you can. :sleepystuff:
So is it likely that I have reduced the power output capabilities of the engine?
Ive been trying to run it in properly according to a thread in here somewhere...but tonight's episodes have freaked me out a little...
  • <put funny sh*t here>
  • Member For: 18y 1m 26d
I hit the limiter a few times when I first got the car, especially in the 6spd auto going from first to second it took a few goes to learn when to upshift. After a few goes you'll be right.
I do find however I short shift the car at like 4000rpm cos these cars really do not need the balls revved off them to make decent power!
in the wet you can short shift at like 4000rpm and drift up a street up into 3rd gear without even having to thrash the balls out of the motor
