Shocker At The Strip
gilto
  • Member For: 17y 8m 4d
Went to WSID tonight and only got 1 run in 'cus of the sh*tty rain. It was my very first run and by the time it looks as though I stuffed it up....it's a BA 4 speed
I had the tyres at 20psi, held the brake with about 2000rpm and left the line ok, manually shifted at 5500rpm 1st to 2nd and 2nd to 3rd...
Here is what the card says.....
ET 14.077
60' 2.328
MPH 101.83
Kph 163.88
Any ideas as to what I did wrong...what should my time be according to the 101.83 miles per hour???
Would appreciate someone who has knowledge in this area to let me know....many thanks in advance.......!!
  • Replies 43
  • KILL,KILL,KILL,DIE,DIE,DIE,
  • Member For: 18y 10m 1d
If you have an auto id leave it in performance drive, rahther than manual shifting that should drop your time by a fair bit :spoton:
E.g. with mine I tryed manual shifting and I run a 13 then I put it into perf drive and run a 11.8, mine does have around 300 rwkw though but you can see the difference in what the drive can do.
  • Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car
  • Member For: 21y 8m 11d
Hey Rob your 60ft is bad for an auto,I would leave the tyres at 20psi get them nice and warm with a good burnout put it in performance auto stall it to 2000rpm for about 5 sec and let it rip
CYA JEFF :spoton:
  • Seriously Flukey Member
  • Member For: 20y 11m 12d
Your right Jeff, but also his MPH is very low. With that power level he should be running 110MPH atleast, assuming the claimed power output is correct.
