My Brake Upgrade Twin Pbr 355mm Front, Bf 328mm Rear
  • Member For: 20y 1m 15d
  Adam said:
Are the PBR calipers the same as the ones supplied in the PBR 'upgrade kits'?
Because you can get a complete kit (front and rear) for what you paid for the fronts.
Adam, are you referring to the upgrade kit that is basically the same as the Ford premium brakes? If so, I think the calipers Hazey has are different. I'm not 100% sure, but I think the PBR kits supply C6 calipers and 325mm rotors - Hazey has C5 calipers and 355mm rotors. But both appear to be the same 32mm thickness.
And, as you know, the BA premium brake package uses the same rear calipers as stock - the PBR upgrade kit just supplies them powder coated in red. :spoton:
  • Silver Donating Members
  • Member For: 19y 11m 10d
I've read the spiel by race brakes sydney on the AFF site but looking at these calipers, I'm convinced they are C6 items. C5's have fins... me no understand?
  • Member For: 21y 10m 12d
that's what I was thinking too, If you check this thread the caliper looks identical to mine THREAD
  • Member For: 20y 17d
So all I need is the C5 claipers and they will be a direct bolt on and I can run 355mm rotors, cool.
You gotta laugh that our cars didn't come with 4pots standard loads of the little light weight jap cars do. I've already changed rotors to slotted front and rear and pads to Ferodos looking for better braking and I'm still not completely happy. But I cant afford the Brembos.
