hanra Into the laaaake Member 1,532 Member For: 17y 8m 16d Gender: Male Location: Nrth Qld Posted 24/09/07 09:43 AM Share Posted 24/09/07 09:43 AM Have tweeters in the pillars? 03 XR6T. Has a 6 disc ICC. Just curious if this model would have tweeters in the pillars. If so can any aftermarket tweeter fit in there? What size are the door speakers? What size are the rear pillar speakers? Thanks. Link to comment Share on other sites More sharing options...
alpha Member 266 Member For: 17y 11m 26d Gender: Male Location: Perth Posted 24/09/07 10:48 AM Share Posted 24/09/07 10:48 AM I had a 05 ute with tweeter grills , but when I took the the panel off = no tweeter. Bought a set of component speakers -tweeter fit in fine with little modification. Sorry can't remember the size. Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 23d Gender: Male Location: SW Sydney Posted 24/09/07 11:36 AM Share Posted 24/09/07 11:36 AM the door speaker are 5x7, not sure about the tweaters, but they should be in there... Link to comment Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 17y 8m 16d Gender: Male Location: Nrth Qld Posted 24/09/07 11:44 AM Author Share Posted 24/09/07 11:44 AM Its not premo sound or anything. So ill have to have a look see if they are in there.... Can the grill just come off or does the entire pillar trim need to come off? Link to comment Share on other sites More sharing options...
Bad Apples Donating Members 110 Member For: 19y 7m 8d Gender: Male Posted 24/09/07 10:25 PM Share Posted 24/09/07 10:25 PM Its not premo sound or anything. So ill have to have a look see if they are in there.... Can the grill just come off or does the entire pillar trim need to come off?If you don't have Premium sound then probably won't have tweeters. I have "Premium" and did get the tweeters. The little grill pops out no problem, just the little tabs holding it in, use a soft tool, though to avoid marking the plastic. The front and rear speakers are 5x7, same as the sedans.Cheers. Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 23d Gender: Male Location: SW Sydney Posted 24/09/07 11:33 PM Share Posted 24/09/07 11:33 PM also remember, if you have a BA ute, you will have "prestige" sound, not premium sound Link to comment Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 17y 8m 16d Gender: Male Location: Nrth Qld Posted 25/09/07 12:30 AM Author Share Posted 25/09/07 12:30 AM So I wonder if "prestige sound" has tweeters...? It has a 6 disc ICC.... Link to comment Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 17y 8m 16d Gender: Male Location: Nrth Qld Posted 25/09/07 10:54 AM Author Share Posted 25/09/07 10:54 AM There is a tweeter in there. I removed the pillar trim, and it can stay in there for all I care.... Its in the worst spot to try and remove if I wanted to upgrade. Not sure how its attached, but the bracket it sits on is rivited to the pillar..... Link to comment Share on other sites More sharing options...
bob^ Member 170 Member For: 21y 3m 27d Location: Geelong Posted 25/09/07 11:31 AM Share Posted 25/09/07 11:31 AM It's easy to remove once you take the whole A pillar trim off. Just take the door seal off in that area and pop it off.Then you just drill the rivet out. Link to comment Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 17y 8m 16d Gender: Male Location: Nrth Qld Posted 25/09/07 11:55 AM Author Share Posted 25/09/07 11:55 AM Yeah well I had the entire trim piece off. Is it only 1 rivet that holds it in place? How do you go about mounting a new tweeter? Link to comment Share on other sites More sharing options...
