  • Member For: 16y 7m 22d
gday, I have a few questions I need to ask.
I Installed a new stereo to my car and I can hear the revs of my car coming over the speakers when the car is running?
And Second, the ICC now has a blank screen, ive checked all the fuses including (ICC-BAT and ICC-ACC) and none are blown? its not premuim sound btw...
Thanks for any help given :D
  • 9 months later...
  • Member For: 16y 4m 10d
Has anyone just replaced the factory 8" sub and amp for better ones no cutting or anything just disconected factory and slotted in new ones. I did the whole stereo in my old car and I dont really wanna do it again so I am thinking just something with a little more punch that will fit in factory spots??? Anyone done it and any suggestions on sub or amp cheers
  • 2 weeks later...
  • 2 weeks later...
  • Moar Powar Babeh
  • Member For: 19y 6m 26d
Anybody out there know if its possible to stop the ICC screen dimming when the headlights are on? I drive with my headlights on all the time and it makes it nigh on impossible to read the screen during the day...... :blink:
  • 4 weeks later...
  • Member For: 15y 10m 28d
thanks man, I too also have this issue where the stereo just sounds a bit average for 'premium sound' I have it set to ROCK and have to lower the BASS levels. I'm keen to replace the sub... I might just take it to a stereo place and get their input as to me, it sounds lamo sound.. I go to crank it and the sub rattles. :-(
  On 05/08/2008 at 7:44 AM, quadie said:
check to make sure u havent torn the rubber seal around the cone .. pull off the undertray from the boot by removing hte 3 white plastic clips around the boot light , and have a look up there give it a shake , may also be just a loose bolt or child restraint mount
  • Member For: 16y 2m 22d
Im also interested if anyone knows how to do this, but around the other way lol. I prefer the night style darker light on the colour screen and I'de like the screen to stay dark with the headlights off. No troubles reading it during the day and I think it looks better. Most of the time it's just saying "AUX" anyway due to iPod usage.
Edited by NAT88S
  • Go Pies!!!
  • Member For: 17y 2m 1d
There is normally a trigger wire hanging out the back end of a ICC/HU.
1. Remove the ICC
or
Locate the wire in question (if it exists in these things... I would guess it does).
2. Pull bonnet release switch located beside the foot well on the drivers side.
3. disconnect the battery.
4. remove the icc (if required, or take a pit stop and get a can of beer, coke, or glass of vodka whatever you prefer).
5. with a sharp cutting (plier style) tool - CUT THE BASTARD!
6. tape up the ends, just in case of shorting out.
7. put everything back together and off you go!
This may work - if it was just a head unit type deck this is all that you need to do. I can only assume the ICC has a like wire somewhere - just need to find the bastard...
:beerchug:
  • 2 weeks later...
  • Go Pies!!!
Mate, under the ICC just to the right of the power 12v plug...
also in the fuse box on the right hand side of the steering wheel - there is a AUX for a mobiel car kit!
good luck!
:wtcslap:
