ray62 Inactive Members 1 Member For: 17y 2m 26d Posted 23/01/08 10:02 AM Share Posted 23/01/08 10:02 AM hey just looking to fit mp3 aux cable to stereo as there is a holder next to power source at the back which is made to fit female plug forthe mp3 cable, just wondering if anyone knows how to take side panel off to get to.cheers ray. Link to comment https://www.fordxr6turbo.com/forum/topic/38467-general-audio-questions/page/4/#findComment-624393 Share on other sites More sharing options...
howitzer85 Member 241 Member For: 18y 1m 28d Gender: Male Location: The marsh... Posted 23/01/08 10:44 PM Share Posted 23/01/08 10:44 PM pop the gear lever surround off, under there are screws that hold those corner wing pieces on, once there outta the way there are another two screws either side of the tissue box holder. remove these and it'll slide out...you dont need to take the side panel off, just need to spend some time feeding the wire thru... Link to comment https://www.fordxr6turbo.com/forum/topic/38467-general-audio-questions/page/4/#findComment-624674 Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 5m 9d Gender: Male Location: left right out Posted 15/02/08 09:03 PM Share Posted 15/02/08 09:03 PM Hi guys, I have a 12' boxed rockford fosgate sub and amp, and am going to install in the t. What I need to know is , does any one have or know where to find a wiring diagram for the factory amp, as I am going to use the input wires from the head unit where they enter the amp and also the remote on from the head unit where it enters the amp. By using these wires, the sub will still turn on and off when the stereo is used without the keys in the ignition. I am aware these signal wires are high level , but my amp has high and low level inputs so all good. Link to comment https://www.fordxr6turbo.com/forum/topic/38467-general-audio-questions/page/4/#findComment-634763 Share on other sites More sharing options...
SubJimbo ŠύЂפֿĺmβø ™ Donating Members 1,216 Member For: 17y 3m 16d Gender: Male Location: Melbourne Posted 16/02/08 01:26 PM Share Posted 16/02/08 01:26 PM Hey guys,I was thinking about eventally putting in some Alpine Type "S" 5x7 Coaxial Speakers in the Front / Rear of my BA MKII, And I was just wondering if they will fit straight into the place of my Stock speakers, Or if I need something made up for them to fit in..And also, I have 2x 12" Alpine Type "S" Subs, But with no Amp.. If I wanted to go with a system like this, Anybody have any reccomendations on which AMP(s) I should buy?, There the only thing I'm not sure on... Link to comment https://www.fordxr6turbo.com/forum/topic/38467-general-audio-questions/page/4/#findComment-635047 Share on other sites More sharing options...
jEtONiT Donating Members 1,817 Member For: 21y 5m 11d Gender: Not Telling Location: next door.. Posted 17/02/08 05:17 AM Share Posted 17/02/08 05:17 AM hey guys.. I was wondering whether someone has the dimensions for the biggest sub box that will fit in the space behind the boot on the sedans.. also, does anyone have a template for the 5x7 to 6.5" speaker adapter baffles.thanks. Link to comment https://www.fordxr6turbo.com/forum/topic/38467-general-audio-questions/page/4/#findComment-635216 Share on other sites More sharing options...
jEtONiT Donating Members 1,817 Member For: 21y 5m 11d Gender: Not Telling Location: next door.. Posted 17/02/08 10:01 AM Share Posted 17/02/08 10:01 AM jEtONiT said: hey guys.. I was wondering whether someone has the dimensions for the biggest sub box that will fit in the space behind the boot on the sedans.. also, does anyone have a template for the 5x7 to 6.5" speaker adapter baffles.thanks.**behind the seat in the boot of the sedans.. my bad.. Link to comment https://www.fordxr6turbo.com/forum/topic/38467-general-audio-questions/page/4/#findComment-635353 Share on other sites More sharing options...
SubJimbo ŠύЂפֿĺmβø ™ Donating Members 1,216 Member For: 17y 3m 16d Gender: Male Location: Melbourne Posted 18/02/08 09:35 AM Share Posted 18/02/08 09:35 AM (edited) K'mon you Audio Smarties! Ill make my own thread!! =O Edited 18/02/08 09:40 AM by SubJimbo Link to comment https://www.fordxr6turbo.com/forum/topic/38467-general-audio-questions/page/4/#findComment-635713 Share on other sites More sharing options...
animalxr6t Member 186 Member For: 17y 3m 8d Gender: Male Location: riverland south aus Posted 19/02/08 08:50 AM Share Posted 19/02/08 08:50 AM hey guys just a quick one. where is the factory amp located for premo sound if one exists and if I upgade the sub is it doable to just replace the factory amp with a higher quality one for better sound Link to comment https://www.fordxr6turbo.com/forum/topic/38467-general-audio-questions/page/4/#findComment-636123 Share on other sites More sharing options...
jEtONiT Donating Members 1,817 Member For: 21y 5m 11d Gender: Not Telling Location: next door.. Posted 19/02/08 01:13 PM Share Posted 19/02/08 01:13 PM when you open the boot its on the left hand side quarter hidden by some carpet. theres a couple of plastic screw thingy's which need to be pulled out to be able to see it.as for the other question, im guessing it is possible, but someone with more knowledge will need to go into more depth to give you a proper answer, im an amateur. Link to comment https://www.fordxr6turbo.com/forum/topic/38467-general-audio-questions/page/4/#findComment-636201 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 10m 23d Gender: Male Location: Melbourne Posted 19/02/08 11:06 PM Author Share Posted 19/02/08 11:06 PM (edited) jEtONiT said: hey guys.. I was wondering whether someone has the dimensions for the biggest sub box that will fit in the space behind the boot on the sedans.. also, does anyone have a template for the 5x7 to 6.5" speaker adapter baffles.thanks.Mate mines probably the biggest you can physically fit in that spot as long as you don't have premo sound. If you do then you gotta tear out the crappy sub on the parcel shelf and cut the bump out from underneath otherwise you won't be able to get big sub boxes past it. I'll measure mine up tonight and let you know, if that helps. animalxr6t said: hey guys just a quick one. where is the factory amp located for premo sound if one exists and if I upgade the sub is it doable to just replace the factory amp with a higher quality one for better soundYeah that's usually one of the first upgrades people do, you will get more kick and bass but unfortunately the front and rear speakers will still let the sound quality down. If you got the cash you might wanna do the whole lot in one go, then you can update all the wires and sound proofing giving you the best sound possible. Edited 19/02/08 11:10 PM by XRTPSI Link to comment https://www.fordxr6turbo.com/forum/topic/38467-general-audio-questions/page/4/#findComment-636246 Share on other sites More sharing options...
