  • Member For: 16y 6m 2d
so any info on what size the front and back speakers are on a fg premo sound????
o relise the fronts are splits are the backs two ways???
Edited by lukedohc
  • 2 months later...
  • Member For: 18y 5m 23d
  On 11/08/2010 at 3:04 AM, lukedohc said:
can you give me the sizes of the front spilts and the rear speakers whatever they are I don't really wanna put another head unit in would like to use the standard one and amp the speakers with the sub I wanna try and keep my boot if I can
Go with JL Audio Slash amps, and the Hertz Mille speakers are nice for Metal. JL Slash amps have differential balanced inputs so you want get ground loop interference (alternator whine) like 99% of amps will give you. Also, they will accept high level speaker inputs from the OEM deck, so no need for a line out converter. Beware, the OEM system is noisey though...
Front speakers in the FG are an integrated type. They are designed to seal with the door trim. The cutout is not round like a normal speaker, which will require a baffle to be made. Results will be average if you don't seal with the trim due to the number and size of the service holes in the mounting baffle.
This last pic will give you an idea on how much work is required to seal up towards the trim. This isn't perfect btw, and was me just experimenting.
  • 1 month later...
  • Member For: 17y 1m 18d
The cd player in my ute has stopped working, as my dad owns a wreckers I have just fitted another ICC but now the screen just says CODE and the ute wont start. I have a rang three local ford dealers and have got three different answers, what is the answer to get the new ICC to work and the ute to start.
P.S. only standard ICC not premium if it matters
  • 1 month later...
  • Member For: 16y 2m 7d
Does anyone know how to get BA premium sound into aux mode... I know u press the am button twice normally but in my car nothing happens... Do I have to have the aux cable installed before it will activate..? Any ideas...
  • Member For: 21y 7m 12d
Yes, you will need to buy the aux kit (powered or non powered one) if it doesn't have it installed before it will be active
  • Member For: 15y 2m 28d
Is the aux system only avaliable on the prem systems or does it work on normal ones?
  • Sucker
  • Moderating Team
  • Member For: 20y 11m 21d
Nah you can plug it in to anything, once the ICC detects it's there you access it with the AM button from memory.
