tab Sucker Moderating Team 32,303 Member For: 21y 5d Gender: Male Location: Brisbane Posted 18/09/07 11:51 AM Share Posted 18/09/07 11:51 AM Good idea until your air-con goes crazy...it bases fan speed and conditioning based on the sunlight sensor and outside temperature. Link to comment https://www.fordxr6turbo.com/forum/topic/38402-where-is-the-outside-temp-sensor-located/page/2/#findComment-575937 Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 5m 16d Gender: Male Location: Dé·jà vu Posted 18/09/07 12:09 PM Share Posted 18/09/07 12:09 PM SavageD said: How do you guys know this sh*t? I'd never even noticed that little bump before. Max Power said: Not really a bump. More like a nipple. Have you ever given a woman orgasm SD....Couldnt help it sorry.... Link to comment https://www.fordxr6turbo.com/forum/topic/38402-where-is-the-outside-temp-sensor-located/page/2/#findComment-575951 Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 19y 1m 6d Gender: Male Location: nsw Posted 18/09/07 12:16 PM Share Posted 18/09/07 12:16 PM if you use a 3 or 4 position switch with position 1 being standard you could select p1 and use the aircon, and only use the other ones when testing the air temp.you dont really use the aircon when driving hard do you. Link to comment https://www.fordxr6turbo.com/forum/topic/38402-where-is-the-outside-temp-sensor-located/page/2/#findComment-575953 Share on other sites More sharing options...
Max Power Member 381 Member For: 20y 11m 27d Location: MENAI, NSW Posted 18/09/07 12:20 PM Author Share Posted 18/09/07 12:20 PM tab said: Good idea until your air-con goes crazy...it bases fan speed and conditioning based on the sunlight sensor and outside temperature.that's good to know tab so thanks. Though I think that when I need to know under bonnet or airbox temps, Id be thinking about going wot and not comfort. You have, however, given me a good idea about how to boost the cooling down of the interior when I need to (bloody black cars in summer) Link to comment https://www.fordxr6turbo.com/forum/topic/38402-where-is-the-outside-temp-sensor-located/page/2/#findComment-575958 Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 19y 1m 6d Gender: Male Location: nsw Posted 18/09/07 12:25 PM Share Posted 18/09/07 12:25 PM (edited) im into electronics max, it may be the case that if you put a variable resistance attenuator inline with the sensor you can adjust the signal from the sensor to the icc and make the ac system think its 50 degrees outside. Edited 18/09/07 12:25 PM by BFHOON Link to comment https://www.fordxr6turbo.com/forum/topic/38402-where-is-the-outside-temp-sensor-located/page/2/#findComment-575960 Share on other sites More sharing options...
