ex-are-six Member 12 Member For: 20y 10m 12d Posted 17/09/07 01:10 AM Share Posted 17/09/07 01:10 AM Goodaye,I have an Aug 03 manual (5Speed) XR6T, not modded and driven by my wife 95%, has about 56,000kms.The gears have always been difficult to shift but getting more difficult lately, now impossible to get reverse gear, just wont go in at all, cannot move car, other gears are OK.Any recommendations as to what this may be and suggested fix, I am in Sydney.Also once this has been fixed what oil should I put in the box? Transmax?Thanks,Mark Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 17y 9m 6d Gender: Male Location: ACT Posted 17/09/07 01:21 AM Share Posted 17/09/07 01:21 AM How black is your Clutch Fluid ?Bleed and replace the Clutch Fluid 1st and see how you go. Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 17y 11m 24d Gender: Male Location: SW Sydney Posted 17/09/07 01:28 AM Share Posted 17/09/07 01:28 AM yeah, I'd try that, if that fails, it could be the clutch maybe? Link to comment Share on other sites More sharing options...
ex-are-six Member 12 Member For: 20y 10m 12d Posted 17/09/07 04:21 AM Author Share Posted 17/09/07 04:21 AM yeah, I'd try that, if that fails, it could be the clutch maybe?Thanks for that, I know it hasnt been changed for a while so I will give that a go Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 8m 5d Gender: Male Location: Melbourne Posted 17/09/07 06:55 AM Share Posted 17/09/07 06:55 AM Same thing happen to me mate, about 3 weeks after I bought it. First 5th gear went, then reverse at this time I thought id bought a lemon but it turned out a bolt came loose in the selector, ease fix took em a day to pull the box out change oil an tighten it all back up. Link to comment Share on other sites More sharing options...
G6ET8U Playing with Sports Bikes... Silver Donating Members 1,927 Member For: 19y 3m 2d Gender: Male Location: Whistling, GTX. Posted 18/09/07 04:39 AM Share Posted 18/09/07 04:39 AM When my car had the 5 speed in it, many moons ago now. I had a problem with the gear shift, it felt very vague, would crunch in to gear and would be difficult to select gears... it was completely stock at the time and still under warranty, so I took it to Ford and they replaced the shifter block.After they did that it was good as new... until it came out in lieu of a T56 conversion.Jack Link to comment Share on other sites More sharing options...
Ford_Power Member 798 Member For: 21y 9m 30d Posted 20/09/07 07:17 AM Share Posted 20/09/07 07:17 AM I'd go with option A most likely.Replace and bleed clutch fluid - cheapest and easiest to try solution.I bleed my clutch regularly - once every 3 months or so as the shift starts to slowly deteriorate. Link to comment Share on other sites More sharing options...
