  • THE PSYCHO XRT
  • Member For: 19y 5m 11d
  • Gender: Not Telling
  DORKO said:
Thanks for all your advice people.
PS: EXLNT---> HOT BONNET! :tonguepoke:
Dorko
Thanks buddy.I've got some more goodies on the way. Once its all done up
ill post up sum pics. :tonguepoke:
  • Member For: 21y 3m 29d
  DORKO said:
Well today I opened up the bonnet to put some water in the windscreen thingy. I notice some pink stuff coming out of this thing below.
Should I be concern? Its not leaking... its dry. I took my ute for a spin and trashed it to see if it would leak, but nothing changed.
Any comments would be appreciated.
Thanks in advance Dorko :spoton:
I hope it isn`t tranny fluid mixing with your coolant as this is a known problem and a reason why some people bypass the radiator for their tranny cooler.
Check your overflow bottle you coolant should be green.
  • Member For: 19y 1m 28d
You can get red coolant, but I have always seen Ford use green coolant. Could be a different case if someone else has done the servicing, just hope your radiator hasn't sh*t a brick and coolant mixing with tranny fluid
  • Member For: 18y 2m 8d
I hope it inst stuffed! The temperture has been fine. the car has always been serviced by ford its only got 23k on the clock. I check the collant tonight... God I hope its nothing huge....
Dorko
  • Moar Powar Babeh
  • Member For: 19y 7m 26d
The green ford coolant turns a pinking white colour when it leaks out and dries up.
If its just the o-ring that goes around the thermostat just go to ford and get another one. 2 bolts to undo, top it up with a little coolant and presto you're done. Just make sure you don't do it while the engine is hot. :tonguepoke:
  • <put funny sh*t here>
  • Member For: 18y 6m 10d
He's booked in soon for a custom tune so they will change the thermostat then so I'd just wait if its not leaking much at all
Spoke to Simon today...booked in the ute for next week. He said he will change the thermo and seal.... :oohwoah:
Said as long as it aint leaking, it should be right for now.... So touch wood it doesnt leak till then...
Thanks for reading :msm:
Dorko
