bjcrown Donating Members 182 Member For: 19y 5m 27d Posted 29/09/07 10:18 AM Share Posted 29/09/07 10:18 AM bjcrown said: Anyone know a good wheel aligment place in Melbourne Eastern / South Eastern suburbs?Anyone please? Link to comment https://www.fordxr6turbo.com/forum/topic/38262-how-do-i-get-the-t-to-handle-better/page/4/#findComment-579597 Share on other sites More sharing options...
shitbmxrider Donating Members 420 Member For: 19y 14d Gender: Male Location: Mill Park, Victoria Posted 30/09/07 06:55 AM Share Posted 30/09/07 06:55 AM fulcrum in berwick have a good name Link to comment https://www.fordxr6turbo.com/forum/topic/38262-how-do-i-get-the-t-to-handle-better/page/4/#findComment-579775 Share on other sites More sharing options...
Erko Donating Members 1,079 Member For: 21y 6m 13d Gender: Male Location: Sydney Posted 01/10/07 10:53 AM Share Posted 01/10/07 10:53 AM EXIT said: DoubleK , after alot of research ( I used to work in the suspension game so I know who to ask) I fitted Bilstein struts, Kings 20mm lowered coils and Super Pro camber adjustable, polyurethane front lower inner control arm bushes to mine. The difference is enormous. The car handles superbly and rides nicely too.I chose Bilsteins because they are a German engineered mono tube design shock which means they have a much larger piston area than most shocks which are twin tube. This gives excellent damping control without small bump harshness so the ride quality is better than the standard suspension even though the shocks are stiffer. Which is why they are used in most Mercedes, Bmw's, some Ferraris etc.I have not driven a T with Teins in it so I can't comment on them.The lower inners are important firstly because they give extra camber adjustment which allows the wheel aligner to get the correct setup as the stock car ofter has insufficient adjustment range. Secondly the stock lower inner is a large soft bushing that allows the wheel alignment to change significantly under cornering and braking loads. The poly bushs fix this. Super Pro are the best engineered poly bushes by far.With the increased spring rate of the King's coils I have found no need for a stiffer swaybar. In my opinion sway bars are rarely required on a road car if the spring and damping rates are correct and usually just result in excessive understeer (or oversteer on the back) and tramlining on uneven roads.Also remember that possibly the most important part of the suspension is the tyres. Good tyres make a huge difference. And find a good wheel aligner ( most suspension specialists) as most wheel aligners just use the settings in the book without much understanding of the underlying principles of dynamic wheel alignment. It is quite possible to align a car to within the recommended specs and have it steering poorly or wearing tyres. A good tip in this regard is if the guy who does the alignment doesn't test drive the car after he's finished then he probably hasn't a clue.Great post mate. Excellent tip on the bushes.Do you know what the King spring rates are and how they compare to stock ?Like you I have always favoured a heavier spring rate with matched damping rather than going with larger sways bars, which imho compromise the independance of the suspension somewhat. Link to comment https://www.fordxr6turbo.com/forum/topic/38262-how-do-i-get-the-t-to-handle-better/page/4/#findComment-580112 Share on other sites More sharing options...
EXIT Member 41 Member For: 18y 3m 18d Location: Brisbane Posted 02/10/07 01:04 PM Share Posted 02/10/07 01:04 PM Rob E said: Great post mate. Excellent tip on the bushes.Do you know what the King spring rates are and how they compare to stock ?Like you I have always favoured a heavier spring rate with matched damping rather than going with larger sways bars, which imho compromise the independance of the suspension somewhat.I'm not sure of the actual spring rates but King's could tell you for sure. Generally I beleive their springs are approx 20 - 25% stiffer than the stock springs. Someone may want to correct me on that though. Link to comment https://www.fordxr6turbo.com/forum/topic/38262-how-do-i-get-the-t-to-handle-better/page/4/#findComment-580671 Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 19y 22d Gender: Male Location: nsw Posted 08/10/07 11:33 AM Share Posted 08/10/07 11:33 AM street slicks.I have a set of yokos on mine at the moment handles like its on rails. Link to comment https://www.fordxr6turbo.com/forum/topic/38262-how-do-i-get-the-t-to-handle-better/page/4/#findComment-582628 Share on other sites More sharing options...
EZ2CME Formerly XR6NA Member 3,512 Member For: 19y 4m 16d Gender: Male Location: Brisbane Posted 08/10/07 11:37 AM Share Posted 08/10/07 11:37 AM How do they go in the wet? Link to comment https://www.fordxr6turbo.com/forum/topic/38262-how-do-i-get-the-t-to-handle-better/page/4/#findComment-582633 Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 9m 8d Gender: Male Location: The 8th Dimension Posted 08/10/07 11:42 AM Share Posted 08/10/07 11:42 AM I would say it would be scary in any more than a drizzel. Link to comment https://www.fordxr6turbo.com/forum/topic/38262-how-do-i-get-the-t-to-handle-better/page/4/#findComment-582636 Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 19y 22d Gender: Male Location: nsw Posted 08/10/07 11:45 AM Share Posted 08/10/07 11:45 AM I havnt had the chance yet to see how they go in the wet but they really are a wet slick, should be better than a road tyre with lots of tread on them. soft rubber.I get them cheap 60 bucks each from a guy I know who races, in the dry I can feel a noticable difference, more stable and no wheelspin in first, just a little rrrt not a squeal like road tyres.when u throw it into second theres no sideways just a rrrt and off u go... im hooked.as u can see by the pic they have plenty of meat left and have been cooked but are still sticky.I do a good burnout on them and the top layer is gone, Link to comment https://www.fordxr6turbo.com/forum/topic/38262-how-do-i-get-the-t-to-handle-better/page/4/#findComment-582638 Share on other sites More sharing options...
loopism Tractor Driver Member 709 Member For: 19y 2m 5d Gender: Male Location: Sydney Posted 11/10/07 12:09 AM Share Posted 11/10/07 12:09 AM and I bet they last about 1500km Link to comment https://www.fordxr6turbo.com/forum/topic/38262-how-do-i-get-the-t-to-handle-better/page/4/#findComment-583425 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 2m 8d Gender: Male Location: SW Sydney Posted 11/10/07 12:28 AM Share Posted 11/10/07 12:28 AM WAIT! Did you say 60 BUCKS! dude I'll buy four right now and pay for a case of beer! gimme gimme gimme! Link to comment https://www.fordxr6turbo.com/forum/topic/38262-how-do-i-get-the-t-to-handle-better/page/4/#findComment-583433 Share on other sites More sharing options...
