Big Gaz Member 9 Member For: 17y 11m 3d Location: Scotland originally but living and working down near London Posted 13/09/07 12:14 AM Share Posted 13/09/07 12:14 AM Ok I know there is a good How To at the top of the page and the actual job of changing the oil isn't too hard, but my problem is a little bit more complicated.As I said doing the job is a piece of piss but getting the oil is a little more difficult.Castrol what ever it is that is recommended in the How To isn't available over here in the UK so I've come up with a cunning plan and would like to sound it out with you guys before I did it.On the back of the Castrol bottle it says that it is suitable for various cars. Now Vauxhall import the Holden/HSV coupes into the country and sell them under the VXR8 brand. Sooooo...... would I be able to use the oil that Vx specify for the VXR8 in my ute's diff, I'm assuming they will have any additional additives as well if not already premixed. Failing that, would Jaguar stuff do? as it mentioned as well.I may be missing something and there is something basically flawed with my thinking but hopefully someone here might know.CheersGarrick Link to comment https://www.fordxr6turbo.com/forum/topic/38250-replacing-diff-oil-when-the-right-oil-isnt-available/ Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 9m 7d Gender: Male Location: NSW Posted 13/09/07 04:46 AM Share Posted 13/09/07 04:46 AM Ive been using Shell LS90 in mine since new under the advise of Mal Wood Oil Thread Link to comment https://www.fordxr6turbo.com/forum/topic/38250-replacing-diff-oil-when-the-right-oil-isnt-available/#findComment-574154 Share on other sites More sharing options...
ENVY-T CNUTOX Donating Members 3,098 Member For: 22y 4m 19d Gender: Male Location: Not sure? Posted 13/09/07 05:32 AM Share Posted 13/09/07 05:32 AM I used the same stuff as above. I replaced my diff, and the shell already has a friction modifier in it. Suitable for 4wd and xr6t! Link to comment https://www.fordxr6turbo.com/forum/topic/38250-replacing-diff-oil-when-the-right-oil-isnt-available/#findComment-574165 Share on other sites More sharing options...
igsta Member 371 Member For: 21y 7m 15d Gender: Male Location: Sydney Posted 13/09/07 07:31 AM Share Posted 13/09/07 07:31 AM The new castrol SAF XA 80W 140 has the additive in it already. The old SAF XA did not have the additive. I think it was a 75W 140. I have changed to this oil and it has done wonders to my diff. I Recommend it. Link to comment https://www.fordxr6turbo.com/forum/topic/38250-replacing-diff-oil-when-the-right-oil-isnt-available/#findComment-574196 Share on other sites More sharing options...
GreenXR6T Donating Members 630 Member For: 19y 8m 22d Gender: Male Location: NSW Posted 13/09/07 09:06 AM Share Posted 13/09/07 09:06 AM Just get some good stuff sent over Link to comment https://www.fordxr6turbo.com/forum/topic/38250-replacing-diff-oil-when-the-right-oil-isnt-available/#findComment-574258 Share on other sites More sharing options...
Craig. Member 563 Member For: 18y 2m 5d Gender: Male Location: Sunshine Coast QLD Posted 13/09/07 09:47 AM Share Posted 13/09/07 09:47 AM Gary, there must be a similar product over there for LSD equiped cars. It might be worth getting the specifications of the right oil and then contacting the local Castrol or Shell oil distributors to see if they have a product similar. I have had some success doing this with oil for my bike after an American tuner recommeded a product that is just not availalbe here. Took me a couple of emails sent off to the service dept of one or two oil manufacturers and I had an idential product with a different name.Might be worth a try mate! Link to comment https://www.fordxr6turbo.com/forum/topic/38250-replacing-diff-oil-when-the-right-oil-isnt-available/#findComment-574306 Share on other sites More sharing options...
Big Gaz Member 9 Member For: 17y 11m 3d Location: Scotland originally but living and working down near London Posted 14/09/07 12:45 PM Author Share Posted 14/09/07 12:45 PM GreenXR6T said: Just get some good stuff sent overI will, I'm slowly getting a big list of bits and bobs for the car (just got to work out how to pay for them :D)Thing is with the diff whine present I need to change the oil asap. Doing a little resarch I can get Redline 80w-140 and the friction modifier from them as well.I've seen it mentioned on here so might go with that just now untill I can get some stuff from down under.Garrick Link to comment https://www.fordxr6turbo.com/forum/topic/38250-replacing-diff-oil-when-the-right-oil-isnt-available/#findComment-574775 Share on other sites More sharing options...
f-wolf Member 897 Member For: 18y 29d Gender: Male Location: ACT Posted 14/09/07 11:25 PM Share Posted 14/09/07 11:25 PM Big Gaz said: Ok I know there is a good How To at the top of the page and the actual job of changing the oil isn't too hard, but my problem is a little bit more complicated.As I said doing the job is a piece of piss but getting the oil is a little more difficult.Castrol what ever it is that is recommended in the How To isn't available over here in the UK so I've come up with a cunning plan and would like to sound it out with you guys before I did it.On the back of the Castrol bottle it says that it is suitable for various cars. Now Vauxhall import the Holden/HSV coupes into the country and sell them under the VXR8 brand. Sooooo...... would I be able to use the oil that Vx specify for the VXR8 in my ute's diff, I'm assuming they will have any additional additives as well if not already premixed. Failing that, would Jaguar stuff do? as it mentioned as well.I may be missing something and there is something basically flawed with my thinking but hopefully someone here might know.CheersGarrickJust take it from here !https://ssl11.lon.gb.securedata.net/classic...products_id=973 Link to comment https://www.fordxr6turbo.com/forum/topic/38250-replacing-diff-oil-when-the-right-oil-isnt-available/#findComment-574820 Share on other sites More sharing options...
Big Gaz Member 9 Member For: 17y 11m 3d Location: Scotland originally but living and working down near London Posted 16/09/07 10:57 PM Author Share Posted 16/09/07 10:57 PM f-wolf said: Just take it from here !https://ssl11.lon.gb.securedata.net/classic...products_id=973If that stuff will do I can go and get it tomorrow. Found a supplier quite near to me so its just a case of popping down picking some up and jobs a good un Garrick Link to comment https://www.fordxr6turbo.com/forum/topic/38250-replacing-diff-oil-when-the-right-oil-isnt-available/#findComment-575375 Share on other sites More sharing options...
