  • Member For: 17y 11m 5d
BF's don't need em updated but I see your point, there is heaps of BA's running over 300 on stockies, which I thought was a no no.
Edited by XRTPSI
  • Member For: 17y 3m 10d
Car: BF MKII 06 XR6T UTE
Trans: 6 speed MANUAL
Power: 342.5 rwkw - 460 rwhp
Boost: 14.5 psi
Induction: plazmaman
Turbo: waste gate mod and actuator
Valve Springs: stock
Exhaust: 3.5" mandral bent 4" cat
Fuel system:60lb injectors
Power adder: high torque performance
  • Member For: 17y 3m 12d
Bf xr6t, p/w plenum, intercooler and custom pod. 6 spd man, ceramic clutch, 60lb inj with gss341 pump, full 3.5 inch x-force ex with twin dump and 10 psi capa flash. Custom tune soon with valve springs.
  • Member For: 18y 14d
Car: Bf Mk1 XR6 Turbo
Trans: 6 speed autor
Power: 340rwkw
Boost: 13 trailing down to 12
Induction: pwr cooler custom pipe work
Turbo: Stock
Valve Springs: Stock
Exhaust: standed with a gutter cat
Fuel system: Siemens injectors, stock fuel pump
im also running a colder thermostat
  • Member For: 18y 4m 6d
Car: BF Mk1 XR6T
Trans: ZF6 Auto
Power: 326 RWKW
Boost: 13PSI
Induction: Process West Stage 1 Cooler, 2nd CAI Typhoons
Turbo: Stock
Exhaust: Stainless 4' Dump and 5' cat, stock the rest of the way
Fuel System: Nizbro Injectors
Power Adder: Xtreme Custom Tune
  • Member For: 19y 10m 25d
Its just a question of luck with the early BAs, some valve springs were a bit weak.
  • 4 weeks later...
  • Member For: 17y 5m 28d
Car: ba mk1
Trans:4sp auto with pwr cooler
Power:246rwkw
Boost: 11PSI
Induction: Typhoon 2nd CAI, kn filter
Turbo: Stock
Exhaust: stock
Fuel System:siemans Injectors ,walbrogss294 pump
Power Adder: Xtreme ford tuning
  • 2 weeks later...
  • Member For: 17y 4m 3d
Car: ba mk1
Power:285rwkw
Boost: 12PSI
Induction: Typhoon cooler + 2nd CAI, kn filter
Turbo: Stock + 8 psi actuator
Exhaust: 3" X-force ss pipe.
Fuel System:siemans Injectors ,walbro pump
Power Adder: BPT tune and thermostat
  • Member For: 17y 11m 4d
Car: BA mk1
Trans: 4sp auto
Power: 301rwkw
Boost: 15PSI
Induction: RAPID I/C & CAI with k&n pod
Turbo: Stock
Valve Springs: Nizpro
Exhaust: 3" X-force high flow cat, the rest stock.
Power Adder: NIZPRO tuned
  • Member For: 17y 7m
Name Mat
Car: BA Mk1 XR6 Turbo
Trans: 4sp Auto
Power: 248.5rwkw
Boost: 14 trailing down to 9
Induction: K&N PAnel Filter, stock intercooler, stock piping
Turbo: Stock
Valve Springs: Heavy Duty
Exhaust: Stock
Fuel system: Siemans Injectors
Power adder: CAPA Box, C&D custom tune.
