  • 3 months later...
  • New Member
  • Member For: 10y 4m 20d
Car : 2006 bf mk1
Trans: 6 speed manual
Turbo: stock flapper mod 12psi actuator
Boost : 11 down to 9
Valve spring : heavy duty not sure which
Cooler : stage 2, plasmaman 3 inch piping, wrap around cold side
Fuel : Bosch intank, injectors upgrade not sure size
Exhaust : 3 inch, hi flow cat , middle muffler delete split to 2.5 inch
Power : 315 rwkw
Tuning : paramount performance Toowoombaa50cc58cfcc87677603bb8add95cc099.jpg
Edited by weavel
  • Bronze Donating Members
  • Member For: 13y 9m 11d
  On 27/07/2014 at 9:58 AM, gaz097 said:
Update
Power: 425rwkw,
Boost: 20psi tapering off a little
Zorst: 4" dump,5" cat into unknown brand dual 2.5" system.
Intercooler: large rapid with standard hotside and 3" wrap around coldside.
Fuel system: 100lb injectors & twin 044's of a custom surge with a walbro intank.
Induction: custom made 4" intake and airbox
Turbo: gcg turbo with 0.7 housing and standard wheels.
Atomic valve springs, spool rebuild kit, arp bolts after previous bad experience with plaz valve springs.
Tuning: vcm by Pbe dynotech on eflex.
Update
Power: 460rwkw,
Boost: 26psi tapering off a lot
Turbo: gtx35 with ported gate.
Atomic valve springs, spool rebuild kit, arp bolts etc. Built by me in the shed.
  • 1 month later...
  • Member For: 14y 1m 28d
  On 04/06/2014 at 10:43 PM, Future said:
Car: BA XR6T
Trans: 4 Speed Auto
Power: 265rwkw with 890nm torque
Boost: 15psi
Induction: Custom Air Box with Pod Filter
Intercooler: Stage 3 Process West with hot and cold side piping
Turbo: Wastegate ported with bigger flapper and 10psi actuator
Valve Springs: Atomic Heavy Duty
Exhaust: Venom 3.5" Dump with High flow cat
Fuel Sytem: KPM 1000cc Inectors with 500hp Walbro Fuel Pump
XCAL4 flash tuned by Elite Automotive on BP Ultimate 98
Don't know whats holding me back, can the cat back restrict that much?
My 03 BA XR6R is now back in the shop having a bf 06 motor dropped in with a t56 manual conversion, 3.5 inch exhaust, option 4 mal wood clutch, throttle body reloc, pw airbox and new turbo core.
Cant wait to see the numbers it makes!
  • 2 weeks later...
Car: BA XR6T
Trans: 4 Speed Auto
Boost: 15psi
UPDATE
Car: BA XR6T 2003
Trans: 6 Speed manual with mal wood option 4 clutch/flywheel and short shifter (converted from 4 speed auto)
Power: 386rwkw with 1091nm torque (517rwhp)
Boost: 19psi
Engine: BF F6 motor with Billet oil pump gears and Atomik 20% underdrive pulley
Induction: Process West 5" race airbox turbo side, Process West Throttle body relocation
Turbo: Wastegate ported with bigger flapper and 12psi actuator
Exhaust: Xforce 4" dump to 3.5" exhaust with high flow cat
Driveline: 600hp built tailshaft and bf manual diff center
XCAL4 flash tuned by Real Dyno Performance on BP Ultimate 98
Edited by Future
  • Like 2
  • 4 months later...
  • New Member
  • Member For: 10y 2m 20d
Just delivered my G6ET to the tuner today to have new turbo fitted up and other bits added, I fitted a PW stepped cooler and had cat removed (kiwi) a couple of weeks ago so I've been babying it around since then, I'm looking forward to getting this back and are not 100% sure what figures it will make.
Would 360-375rwkw be a stretch for mods done? I welcome any predictions. Will be run on E10 as E85 is still not an easy find.
Car: 2009 G6ET
Trans: Stock (pwr heat exchanger going on after tune)
Power: ???? Any Guess's
Boost: 17-19 ?????
Induction: Stock with air box mod
Turbo: GTX3576R new turbine housing with 37mm flapper mod and 12lb turbosmart actuator.
Valve Springs: Stock
Exhaust: Stock with cat GOOOONE
Fuel system: ID1000 and Walbro module
Power adder: Robin @ Torque Performance
Sent from my iPad using Tapatalk
  • New Member
Car: 2009 G6ET
Power: Peak @ 380rwkw
Boost: 14 nice and safe
Will post up dyno sheet once its emailed through, Robin went in at 6am Saturday morning to get it done for me, LEGEND.
  • Like 3
  • loitering with intent
  • Member For: 21y 8m 13d
Pretty sure she's now a bit different to drive. :dancing:
