Mods To Power Comparison
xr_velocity
  • Dropping a turd
  • Member For: 17y 5m 13d
  On 08/06/2014 at 5:08 PM, MattyP said:
Not trying to be rude it seems xft always make big numbers just from what I used to see on there fb page
Not saying anything about their tuning just dyno seems high
Maybe XFT know how to extract that bit of extra power.
From what I have seen there dyno is on par with most other dynos of the same manufacture.
  • MattyP
  • Cruise Control
  • Member For: 12y 11m 4d
That maybe the case
I'm just saying from what I've seen on there Facebook page and the mods they do the numbers just seem a bit high
I've said before it's only a number and doesn't mean much in the real world
  • New Member
  • Member For: 11y 8m 15d
TXR05, on 01 Feb 2012 - 7:01 PM, said:
  On 01/02/2012 at 9:01 AM, TXR05 said:
Car: 2005 xr6t
Trans: 6 speed manual
Turbo: stock
Boost: 12 PSI
Valve springs: Atomic HD
Induction: Process west wheel arch CAI Hi-flow K&N pod filter
Cooler: Process west stage 3.1 Intercooler kit
Fueling: Walbro in tank pump to 42 pound bosch injectors
Exhaust: 4" dump with screamer ( fed back into exhaust ), 5" 100 CPI Hi-flow cat, 3.5 mandrel bent exhaust to a twin tip muffler
Power: 313RWKW
Tuner: Capa
got a 12.6 @ 114MPH at willobank raceway with a AI temp of about 45 - 50 ( no thanks to sitting there for half hour before each run )
60' time of 2.1 So not the best of launches. Still happy non the less with my time.
  On 11/04/2014 at 2:16 AM, TXR05 said:
Just an update I guess. After randomly losing 80 - 100 RWHP for no apparent reason, had my tune updated to the Xcal 3 and flashed by Real dyno, to pull 402.3hp ( 300RWKW ) on 14 PSI.
Only thing they could tell me as to why I lost so much power was there was a fault with my timing and there was non being put into the engine. They don't know why, and neither did Elite Automotive.
So at least I still have most of my power back now. Really want 400RWKW, but can't on my BA motor.
I know its an old post but what would these sort of mods cost me (roughly)? Ive got the same car, 05 6 speed manual and 300rwkw is my aim for power. The car is bone stock ATM with K&N and Earls turbo oil line, just kicked over to 70,000ks. I am thinking of having it tuned by On-Road parts + Performance because they are 5 mins from me and they recently tuned a BA 5 speed manual Ute and managed to squeeze 403hp (300kw) out of:
- Stock exhaust
- High flow cat
- Front mount intercooler
- 82lb injectors
- Modified intake
-10 PSI
If they can make that power out of those mods I wonder what they can get out of TXR05's mod list
  • Member For: 14y 1m 4d
Every car is different so I wouldnt go off what other cars are doing. Mine for example has mods others are punching well over 300 but only making 265 the 4spd auto contributes though.
  • 4 weeks later...
  • 3 weeks later...
  • Member For: 10y 8m 13d
ba 02 344rwkw turbo- stock valve springs-plazaman bee hive injectors-bosch 60lb fuel pump-walbro 044 surge tank-aftermarket industries/holley dominator pump 4inch dump pipe dual 2.5 stainless from cpi 100 cat centre & rear mufflers flex plate-atomic billet atomic oil pump gears xcal 4 - custom 10psi tume by TUFF TUNE PERFORMANCE 344rwkw 743nm@4750 10psi not pushing it due to stock ba bottom end,waiting on ATOMIC motor to really start pushing things
  • Bronze Donating Members
  • Member For: 13y 8m 19d
  On 25/10/2013 at 5:13 AM, gaz097 said:
09/2006 BF1
6 sp manual
Power: 367rwkw, 1000ish nm.
Boost: 18 tapering to 16
Zorst: 4" dump,5" cat into unknown brand dual 2.5" system.
Intercooler: large rapid with standard hotside and 3" wrap around coldside.
Fuel system: 42lb injectors & walbro intank.
Induction:c custom made 4" intake and airbox
Turbo: Stock with home port job and 12lb actuator
Plaz valve springs
Tuning: vcm by Pbe dynotech.
Total cost of mods under 3k
Update
Power: 425rwkw,
Boost: 20psi tapering off a little
Fuel system: 100lb injectors & twin 044's of a custom surge with a walbro intank.
Induction: custom made 4" intake and airbox
Turbo: gcg turbo with 0.7 housing and standard wheels.
Atomic valve springs, spool rebuild kit, arp bolts after previous bad experience with plaz valve springs.
Tuning: vcm by Pbe dynotech on eflex.
  • 3 months later...
  • Member For: 18y 5m 10d
Car: 2005 XR6T BA Mk2
Turbo: stock with 12 pound actuator
Boost: 18 PSI down to 17 PSI
Cooler: Rapid intercooler with hot and cold side piping, standard inlet manifold
Fueling: Herrod intank
Exhaust: XForce 4" dump, 5" cat, twin 2.5"
Power: 356RWKW
Tuner: CV Performance XCAL4
Edited by xr_velocity
  • 2 weeks later...
  • Too heavy needs boost
  • Member For: 11y 8m 3d
fg 2010
power:359rwkw
turbo:gtx3576r with 12lb turbo smart actuator
port and flap mod
exhaust: 4" turbo back x force exhaust
intercooler: jonny tig (stigmata) custom intercooler
induction: jonny tig (stigmata) custom cold air intake
battery relocation
valve springs: nizpro
fuel: 400L intank walbro
transmission: zf 6speed with pwr furious kit
earls oil line
the little turbo is very impressive and I do recommend it to anyone that wants to keep the fast spool.
power adders: morpowa adelaide
e85 tune soon and built tail shaft and fingers crossed with e85 smash out a 10. :D
Edited by Bizkets is fat?
  • Like 2
  • 3 weeks later...
