  • Member For: 13y 9m 29d
  On 01/02/2012 at 9:01 AM, TXR05 said:
Car: 2005 xr6t
Trans: 6 speed manual
Turbo: stock
Boost: 12 PSI
Valve springs: Atomic HD
Induction: Process west wheel arch CAI Hi-flow K&N pod filter
Cooler: Process west stage 3.1 Intercooler kit
Fueling: Walbro in tank pump to 42 pound bosch injectors
Exhaust: 4" dump with screamer ( fed back into exhaust ), 5" 100 CPI Hi-flow cat, 3.5 mandrel bent exhaust to a twin tip muffler
Power: 313RWKW
Tuner: Capa
got a 12.6 @ 114MPH at willobank raceway with a AI temp of about 45 - 50 ( no thanks to sitting there for half hour before each run )
60' time of 2.1 So not the best of launches. Still happy non the less with my time.
Just an update I guess. After randomly losing 80 - 100 RWHP for no apparent reason, had my tune updated to the Xcal 3 and flashed by Real dyno, to pull 402.3hp ( 300RWKW ) on 14 PSI.
Only thing they could tell me as to why I lost so much power was there was a fault with my timing and there was non being put into the engine. They don't know why, and neither did Elite Automotive.
So at least I still have most of my power back now. Really want 400RWKW, but can't on my BA motor.
  • Member For: 11y 1m 22d
Car: 2008 G6ET
Trans: 6 speed auto
Power: 298.9rwkw
Boost: 14psi
Induction: Herrod CAI
Turbo: Stock
Valve Springs: Stock
Intercooler: Stock
Exhaust: Stock
Fuel system: ID1000's
Suspension: SSL's front, SSSL's rear, monroe shocks
XCAL3 flash tuned & injectors, Herrod CAI, cooler thermostat.
Made 252.4 rwkw stock / tuned by Simon @ XFT
  • 2 weeks later...
  • New Member
  • Member For: 11y 11m 8d
Car: FG G6ET
Trans: 6 speed auto
Boost: 17 psi tapering off to 13psi
Induction: Herrod intake w/K&N filter, Nizpro cooler and piping
Turbo: Stock GT3576r
Valve Springs: Atomic
Exhaust: Custom 3.5" split dump -> xforce 2x2.5"
Fuel system: ID1000's, walbro 400Lph fuel pump, E85
Tuner: XFT
Power: 360rwkw, 890Nm
1/4 mile: 12.002 with massive traction issues.
  • 4 weeks later...
  • Member For: 14y 1m 8d
Car: BA XR6T
Trans: 4 Speed Auto
Power: 258.9rwkw with 870nm torque
Boost: 14psi trailing of to 10
Induction: Custom Air Box with Pod Filter
Intercooler: Stage 3 Process West with hot and cold side piping
Turbo: Stock
Valve Springs: Atomic Heavy Duty
Exhaust: Venom 3.5" Dump with High flow cat
Fuel Sytem: KPM 1000cc Inectors with 500hp Walbro Fuel Pump
XCAL4 flash tuned by Elite Automotive on BP Ultimate 98
