  • Member For: 11y 6m 22d
Hi all... Been reading abit in the mods... Curious as to why figures vary so much with various mods... As there are no specification on the type of Dyno figures are obtained (ie type of Dyno... Calibration of Dyno... Ambient temp... Number of runs when figures are obtained...) anyone any thoughts?
  • 2 weeks later...
  • 1 month later...
  • Member For: 13y 4m 5d
IMO, do the following in one hit:
Fuel pump - drop in total replacement pump and swirl pot kits are now an easy install.
Injectors - 1000's are now the benchmark but there are others (smaller) of course
Intercooler ( a good brand )
Cat and dump (will be debate on this as well.)
12lb actuator.
Depending on the car and the tuner you will get ~300rwkw - which can be adjusted back to suit your needs. I know some get the "300" with the F6 cooler but I could not.
However - for a bux down list, a simple touch up and tune with just 440cc injectors and a fuel pump will see you gain an easy 40 KW at the engine. Opinions vary on the need for a fuel pump but for no more than ~ 500 dollars for a drop in kit it is a real good idea. Fuel starvation and aged fuel delivery components in these engines is a guaranteed formula for a blow up.
  • Member For: 18y 10m 22d
not everybody has their car tuned to extract every last bit of power and be on the edge, we tune to what either power or boost level a customer wants
  • Member For: 14y 1m 2d
Car: BF F6 typhoon
Trans: 6 speed auto
Power: 337rwkw
Boost: 16 psi all the way
Induction: Std intake w/K&N filter, Nizpro stg 1 cooler
Turbo: Stock with port and 12 psi actuator
Valve Springs: Stock
Exhaust: Nizpro 4"
Fuel system: ID1000's, walbro fuel pump
  • Member For: 16y 1m 16d
Car: BF F6 typhoon
Trans: 6 speed auto
Power: 314rwkw
Boost: 15 psi all the way
Turbo: Stock with 12 psi actuator
Exhaust: 3.5" dump with cat, stock cat back
Fuel system: Deka 60. walbro fuel pump
1'4: 11.79@119.4mph
  • Dropping a turd
  • Member For: 17y 5m 22d
  On 08/02/2012 at 10:26 AM, arronm said:
Car: 06 Bf Nizpro F6
Transmission: 6 Spd
Power: 317rwkw
Boost: 10psi
Induction: Nizpro
Turbo: Stock/ Nizpro modified
Valve springs: Nizpro
Exhaust: , 4 inch cat, into twin 2.5 inch cat back system
Fuel pump: Nizpro 044 intank
Intercooler: Nizpro
Injectors: Nizpro
Power adder: Nizpro/XFT
Car runs Nizpro Stage 2 , 2+ and 3.
Car is in the video below
http://youtu.be/8bEe-rXaZ_w
Update.
Car has been retuned and now has nizpro 4 inch exhaust and nizpro big cooler.
Made just under 400rwkw on 98 at 18PSI. (stock turbo with turbine housing mods). Due the high compression pistons in the motor no more boost or timing could be used, BUT a switch to E85 should see close to 500rwkw.
Or possibly a switch to the new nizpro turbo and see what we get.
  • Like 3
  • Too heavy needs boost
  • Member For: 11y 8m 12d
car: fg2010 50t
trans: zf 6speed with pwr furious performance kit
power: 300.8rwkw
boost: 15 with 17 in the mid
intercooler: pw stepped and pipes
turbo: stock with 12lb actuator
induction: stock k/n filter modded box
valve springs:nizpro
fuel system: walbro intank deka 60's
exhaust: stock
power adders: JD tuning hp tune.
still more to come. I'll get the hang of this for now before anymore upgrades. it's the daily drive and I must say I'm very impressed. very easy to drive for the future baby mover. go easy and it's just like stock. put the foot down its like the car has dropped half a ton. off like a bullet. :D
