Mods To Power Comparison
xr_velocity
  • Member For: 13y 7m 17d
Car: BA 2003 XR6 Turbo FGMK2 Bottom)
Trans: Stock BTR atm
Power: 377RWKW
Boost: 18psi
Intercooler: RAPID cooler standard hot-side & 3" cold-side
Induction: 4" turbo-side enclosed
Turbo: 35/40 Stock
Valve Springs: Atomic
Exhaust: xforce stainless (4" dump, high flow cat, dual 2.5")
Fuel system: Walbro in-tank feeding bosh 044 Process West surge tank & 60lb Dekkas
Power adder: Mick @ Pitlane
Trans: T56 Melwood Op3+ Clucth
Power: 377RWKW
Boost: 18psi
Turbo: 35/40 Stock
had to fix up something
  • 1 month later...
  • New Member
  • Member For: 11y 9m 11d
Hi Guys.
I have just come across this thread and I find it very usefull and interesting.
I have recently purchased a 2005 ba xr6 turbo mk2 6 speed manual (all stock) and would like to get it to 300rwkw.
can anyone please adives me on what will get it there and also things that performance shops will suggest, but doesnt actually need doing?
thanks
  • Bronze Donating Members
  • Member For: 13y 8m 19d
09/2006 BF1
6 sp manual
Power: 367rwkw, 1000ish nm.
Boost: 18 tapering to 16
Zorst: 4" dump,5" cat into unknown brand dual 2.5" system.
Intercooler: large rapid with standard hotside and 3" wrap around coldside.
Fuel system: 42lb injectors & walbro intank.
Induction:c custom made 4" intake and airbox
Turbo: Stock with home port job and 12lb actuator
Plaz valve springs
Tuning: vcm by Pbe dynotech.
Totalcost of mods under 3k
  • New Member
  • Member For: 11y 8m 15d
09/2006 BF1
6 sp manual
Plaz valve springs
Under 3k for those mods! Wow hook me up!!
  • Member For: 17y 20d
Taken the dyno record by 37kw for 42lbs.
Hi Guys.
thanks
Hi flow cat
Injectors
Walbro (cheap and stock pump will be getting tired)
Tune
Xcal3
Probably new spark plugs
Chop a muffler if you don't mind the noise.
Pray your valve springs hold up or do them first.
This can get damn close with a manual. Next step cooler, wastegate and actuator. Knockin on the door of 350
  • Member For: 18y 10m 12d
Car: FG G6ET
Trans: 6 speed auto
Power: 320rwkw
Boost: 12
Induction: V8 Air box, PWR intercooler, Herrod piping
Turbo: Stock with port and 8 psi actuator
Valve Springs: Stock
Exhaust: Nizpro
Fuel system: 1000cc injectors, stock fuel pump
