Mods To Power Comparison
xr_velocity
  • Member For: 13y 7m 29d
Cars always struggled to make power with low boost! Previous tunes are as follows
280rwkw 15psi
305rwkw 15psi (new valve springs)
322rwkw 17psi
344 rwkw 17psi E85
305rwkw 18psi (new box & stally + 20" rims)
335rwkw 18psi E85 (new box & stally + 20" rims)
  • Member For: 16y 3m 25d
When you get your car tuned should you put the stanard 17's on or the 19's that will be on the car when driven around.
probably drives around with the 20s. I got mine tuned with 20s that I use everyday
Kosij also the power seems abit low and especially for the amount boost!
my manual bf xr6t made 308@15psi with the same mods as yours and then found the internals of the CAT bent out of shape and reduced the flow. gutted it and made 355 before the retune. so maybe something to consider checking out .
Edited by jonn
  • 4 weeks later...
2800rpm stally
Built btr 4 spd
Pw surge tank
80lb injectors
X force dump & cat
3.5" cat back
Plazmaman Cooler
Plazmaman plenum
Gtx 3582 ported housing
Atomic valve springs
16psi 375rwkw E85
15psi 345rwkw pump
Car is a 05 ba mkII
  • 2 weeks later...
  • Member For: 13y 3m 9d
Car: BA Mk2 XR6 Turbo
Trans: 6 speed manual
Power: 270rwkw
Boost: ~13
Induction: F6 CAI, K&N Filter, stock intercooler, stock piping
Turbo: Stock
Valve Springs: Stock
Exhaust: XForce 4" dump, 5" cat into 3.5" catback.
Fuel system: stock injectors, stock fuel pump
Might be time to upgrade those injectors Josh.
Yeah definitely. They're the limit atm. The dyno number was on a fairly exaggerated dyno so I don't think it's tuned too high to be a problem.
Next will be injectors, intercooler, fuel pump and another tune probably in over a year though.
Edited by joshmcmillan
  • New Member
  • Member For: 13y 5m 23d
2008 Fg XR6
Zf trans
Power: 327rwk
Boost: 15psi
Valve springs: Crow cam springs
Zorst: Manta 4inch dump and twin crossflow cats with Xforce twin 2.5" catback.
Intercooler: Stage 2 Nizpro cooler and piping.
Fuel system: ID 1000 injectors
Induction: Modified K@n airbox
Turbo: Stock with 12lb actuator.
Tuning: Xcal 3 box, Tuned by XFT
