  • Skid Machine
  • Member For: 13y 11m 7d
Car: 2003 xr6t
Trans: 4spd
Turbo: stock
Boost: 12
Valve springs: Performance Springs
Induction: Dose pipe (till I can get something better)
Cooler: Rapid
Fueling: 42lb bosch with stock pump
Exhaust: Stock with high flow cat and removed middle muffler
Power: 290rwkw on a 30 degree day.
Tuner: Dyno Mite
  • Skid Machine
Well I've only had it tuned for a couple of weeks and so far so good. Did a track day last week when it was 35 degree's with no cooler and it just went into limp mode. Must be lucky I guess but I'll put a cooler on it asap.
  • Member For: 13y 10m 15d
I think I might plagiarize you're mod list hahaha. That exactly what I want to chase without having to modifie the trans to heavily.
  • Member For: 17y 1m 11d
  On 16/10/2010 at 11:31 AM, Henz said:
Manual will produce more power on the dyno, slower times down 1/4
Car: BF II xr6t Ute
Trans: T56
Power: 303.6rwkw
Boost: 13~psi
Induction: stock
Turbo: stock
Intercooler: stock
Valve Springs: stock
Exhaust: no middle muffler and 5" cat
Fuel system: 60lb dekas
Update.
Car: BF II xr6t Ute
Trans: T56
Power: 303--> 360+rwk
Boost: 13~psi--> 16psi
Induction: stock--> Stainless 4" intake and box.
Turbo: stock--> ported and 12psi actuator
Intercooler: stock--> plazmaman 1000hp + plenum
Exhaust: no middle muffler and 5" cat--> 4" xforce dump
Fuel system: 60lb's--> process west surge tank+044
  • Member For: 13y 8m 21d
  On 25/11/2011 at 1:10 PM, Kosij said:
Car: 2005 xr6t
Trans: 4spd
Turbo: stock
Boost: 14
Valve springs: stock
Induction: rapid ubp
Cooler: Avo
Fueling: 60lb Siemens with stock pump
Exhaust: 4" dump high flow cat with cat back sports exhaust
Power: 290rwkw
Tuner: Autotech engineering
UPDATE
Car: 2005 xr6t
Trans: 4spd stock
Turbo: stock
Boost: 14psi
Valve springs: atomic springs
Cooler: Avo
Fueling: 60lb Siemens with 255l pump
Power: 306.8rwkw
Don't no what's holding more power back!
  • Bronze Donating Members
  • Member For: 13y 9m 4d
Car: 2005 bf xr6t sedan
Gbox: zf 6 speed
Engine: stock
Turbo: stock
Cooler: monza
Fuel: walbro 255lt and bosch 968s
Exhaust: advance 3.5 dump, stainless 4.5 cat, xforce twin 2.5 mild steel catback
Boost: 16psi peak
Power adder: vcm suite profile tune
Power: 300.8rwkw 630nm torque
More to come stay tuned
