  • Member For: 16y 8m 27d
Update- It's in the 600+ section
Car: 2004 BA Mk2 XR6T Ute
Motor: Custom Built
Trans: Turbo 400 with tranzs brake, 3000 Stall, Hurst Shifter with 2 PWR Coolers + fans
Power: 600+RWKW - With the stall flaring, new 1 on the way soon.
Drive Train: Custom chromyl uni jointed Tail Shaft & Built Diff
Boost: 34 PSI
Induction: Process West Race Kit & Battery to Tray
Turbo: T51r Garrett
Valve Springs: Performance
Exhaust: Custom - 4" Dump, 6" Collector to Twin 3"
Fueled by: 98 pump and Methanol might give Nitromethane/Methanol a go...
Fuel System: Process West Fuel rail, Custom 75 litre cell 4 X Bosch 044 Pumps all -10 braided lines with speedflow gear
Intercooler: PW Stage 3 Race Kit
Injectors: Bosch 160lb's
Water/Methanol injection.
Stoppers: 6 pot Brembos to the front and 4 pot AP racing on the rear.
Rims/Rubber: 20" Vertini Fashions with 315/30 Toyo R888 rear and smaller to the front..
Caltracts with 15" slicks on the way.
Tuner: Blueboosted
  • 2 weeks later...
  • Member For: 16y 1m 29d
Amazing power mate good work! So many great cars here. Love the boosted Fords! :icon_ford:
Thought I would post my stock FG dyno results to start the FG boys along! :beerchug: Mods coming soon :3gears:
Car: 08 FG G6ET
Trans: 6speed ZF
Power: 238rwkw 543nm
Boost: Stock @ 9-10psi
Induction: Stock
Turbo: Stock
Valve Springs: Stock
Exhaust: Stock
Fuel system: Stock
Power adder: None
  • 1 month later...
  • Member For: 14y 3m 13d
Car 07 BF XR6 TURBO
Trans ZF 6 speed auto
Turbo stock
Induction stock air box K&N filter
Intercooler & piping stock
Injectors BTA high flow
Tuned by BTA 288rwkw
  • Member For: 14y 6m 20d
Car: 07 BFii XRT
Trans: 6sp ZF Auto
Turbo: STD
Induction: STD (extra hole cut bunnings spec)
Intercooler: Process West Stage 1
Exhaust: STD (cat change only)
Fueling: JTG Liquid Inj. LPG (taxi spec)
Boost: 10 PSI
Power: 287rwkw
Tuner: Pitlane Performance.
  • Skids?
  • Member For: 15y 11m 24d
Car: BA Mk1 XR6 Turbo
Trans: Built BTR 4 Speed Auto
Power: 340rwkw
Boost: 15psi
Injectors: Deka 60lb
Induction: Rapid under battery CAI
Turbo: Stock, 8psi Actuator
Intercooler: Rapid V2
Valve Springs: Heavy Duty
Exhaust: Centre Muffler Removed, Stock Cat High Flowed
Fuel System: Walbro GSS340
Tuner: Bruce Heinrich (Heinrich Performance and Tuning)
  • Member For: 16y 3m 28d
Car: 05 BA MKII XR6T
Trans: T56 manual, with malwood option 3 clutch
Turbo: Standard with 12psi actuator/ported
Induction: Rapid V2.0 highflow kit with 3.5 inch under battery pod
Intercooler: Rapid V2.0 Intercooler kit with GT34 cold side pipe
Exhaust: 3.5inch dump with screamer---5inch (100cell cat)---3inch straight through----Xforce 2.5
Fueling: Walbro in-tank 600hp fuel pump, Siemens 60lb injectors (surge tank coming soon...)
Valve springs: FG F6
Boost: 15 PSI
Power: 326.3rwkw
Tuner: Bruce Hienrich Performance
Next to come.... 16/17psi tune and 20litre E85 tune :3gears:
anyways here the dyno for my current tune
post-33271-0-90564600-1299645004_thumb.j
  • 3 weeks later...
  • Inactive Members
  • Member For: 14y 1m 7d
Name Eddy
Car: BA Mk2 XR6 Turbo
Trans: 6sp manual
Clutch: C.A.P.A 6 puck
Fly Wheel: Chromoly
Power: 310 rwkw on 15psi
Boost: 15 psi down to 10 everyday
Induction: growler box
Turbo: Stock + actuator
Valve Springs: C.A.P.A
Exhaust: X Force 2.5inch stainless with High Flow Cat
Fuel system: Nizpro 42lb injectors and pump
Intercooler: PWR 3 inch
Power adder: C.A.P.A box, Nizpro custom tune
  • Member For: 14y 6m 15d
Car: 04 XR6 T
Trans: 4 speed
Turbo: Ported and actuator
Induction: K&N filter and Second CAI
Intercooler: Wog Cooler
Fueling: DEKAS + Surge Tank
Valve Springs: Crow Cams
Boost: 16 PSI
Power: 351rwkw
Tuner: Me.
  • Member For: 14y 2m 9d
Car:......... FG 2010 XR50T
Trans:..... ZF auto
Turbo:......Bigger, ported w/g, actuator
Boost:......20psi
Iduction:...Processwest cold air box, hot/cold side pipes
Cooler:.....Processewst stage 2
Fueling:....Processwest surge tank, 800cc injectors
Exhaust:...4" dump, 5" cat, full cat back system
Power:......402rwkw
Tuner:......Jim Tunehouse
:buttrock:
  • 1 month later...
  • Member For: 14y 8m 24d
Car: ba xr6t 2003
Trans: auto 4 speed
Power: 355rwkw
Boost: 16 peek
Induction:custom air intake battery to boot intake next to turbo .hdi intercooler
Turbo: stock as a rock
Valve Springs: for get the name bigger ones but
Exhaust:3.5inch exhaust2.inch off the dump hiflow cat and a muffler
Fuel system: 62lb injects
Power adder: custom tune
:icon_ford:
Edited by Lof818
