  • Member For: 18y 6m 1d
Car: 2005 BA Mk2 XR6 TURBO
Trans: T56
Power: 327 rwkw
Boost: 15 PSI
Induction: RAPID V3 Kit
Exhaust: 4" dump, 5" cat, twin 2 1/2" Xforce
Fuel System: Herrod intank replacement
Intercooler: RAPID Cooler
Injectors: Siemens 60lb's
Tuner: C&V Performance
I am told this is a very conservative tune by C&V. With a better bottom end it easily has 40-50rwkw more by just tuning alone. One day it will happen!
  • Member For: 16y 11m 24d
Car: 2006 BF XR6 TURBO
Trans: ZF 6-speed
Power: 267 rwkw (Has made 282rwkw)
Boost: 11 PSI
Induction: Stock + F6 snorkel
Exhaust: Stock
Fuel System: Stock
Intercooler: Stock
Tuner: Pitlane
Conservative tune due to stock cooler and the warmer weather has made more but started to ping slightly due to the heat.
  • 4 weeks later...
  • Waiting for the 1st N/A 12!
  • Member For: 17y 2m 20d
Trans: ZF 6-speed
Power: 262 rwkw
Boost: 10 PSI
Induction: Stock
Exhaust: Stock
Fuel System: Stock
Intercooler: Stock
Tuner: C & V
ET: 12.5 @ 112mph
  • 1 month later...
  • Skids?
  • Member For: 15y 11m 24d
Car: BA Mk1 2003 XR6 Turbo
Trans: 4 Speed Auto With PWR Trans Cooler
Power: 265.0rwkw
Boost: 13-11 PSI
Induction: Pod Filter In Air Box
Turbo: Stock
Intercooler: Monza Cooler
Valve Springs: Stock
Exhaust: Centre Muffler Removed
Fuel system: Walbro GSS340 With 42LB Ford Motorsport Injectors
Tune: Custom Tuned By Bruce Heinrich
  • 4 weeks later...
  • Member For: 15y 6m 28d
Hi all,
The following done to my BF Typhoon.
Car: Bf 2006 Typhoon
Trans: 6 Auto
Power: 276rwkw
Boost: 12 psi
Induction: , K&N Filter,, stock piping
Turbo: Stock
Exhaust: Herrod cat back exhaust, standard Cat.
Fuel system: Bosch injectors
Regards Chris
NVMYF6
  • 2 months later...
  • Member For: 15y 1m 14d
Car: 2003 BA xr6t sedan
Trans: 4 speed auto + PWR trans cooler
Power: 260rwkw
Boost: 10psi down to 9psi
Induction: Underbattery intake
Exhaust: Center muffler removed
Fuel System: 600hp walbro fuel pump
Intercooler: v2.0 Rapid kit
Injectors: 60lb drilled out
Tuner: Bruce Heinrich
Edited by XR6TCamo
  • Member For: 16y 1m 29d
Trans: 6 Auto
Power: 304.8rwkw
Boost: 12 psi
Induction: , K&N Filter, stock piping
Turbo: Stock
Exhaust: 100cpsi cat.
Fuel system: Deka 60lb injectors, Walbro GSS340 Fuel Pump
Tuner: Dyno-Mite Performance
Trans: ZF 6-speed
Power: 337 rwks
Boost: 14 lb
Induction: Stock + 12lb actuator
Exhaust: Cat + hotdogs
Fuel System: Delphi in tank
Intercooler: HDI
Tuner: C & V
ET: tbc
  • 2 weeks later...
  • Member For: 16y 4m 17d
had it dynoed when stock and posting results for those who dont know the figures..
getting it tuned tomorrow so will post the new results when I get it back.
also what will produce a higher figure with the same mods, manual or auto?
Car: BF II xr6t Ute
Trans: T56
Power: 196rwkw
Boost: dyno says 5psi
Induction: f6 intake
Turbo: stock
Intercooler: Stock
Valve Springs: stock
Exhaust: stock
Fuel system: stock
what will produce a higher figure with the same mods, manual or auto?\
thought 265 was a good outcome, atleast the car will last.
mine now
Car: BF II xr6t Ute
Trans: T56
Power: 265rwkw
Boost: 12psi
Turbo: stock
Intercooler: f6
Exhaust: no middle muffler
Fuel system: stock
