  • Member For: 21y 9m 25d
Car: 06 F6 Typhoon
Transmission: ZF 6sp Semi Auto
Power: 370+rwkw
Boost: 16-17psi
Induction: BPR CAI, stock pipes/cross over, plazmaman UBP
Turbo: Stock turbo with upgraded actuator and ported waste gate
Valve springs: Stock
Exhaust: Dump, high flow cat, Y-pipe, center muffler split into quads with 2x custom mufflers sporting stock GT tips.
Fuel pump: Walbro high flow pump
Intercooler: Plazmaman
Injectors: Re-drilled stock injectors
Power adder: Custom tuned by BluePower Racing
Edited by Daniel
  • Member For: 16y 23d
Car: 06 F6 Typhoon
Power: 382 rwkw
Boost: 18 psi
Induction: Nizpro CAI, Nizpro Plenum
Valve springs: Atomic
Exhaust: 3.5 dump with external, high flow cat, herrods quad rear.
Fuel pump: Herrods in tank pump, PW surge tank
Intercooler: Nizpro big cooler
Injectors: Nizpro
Motor: Mahle pistons, Atomic fat rods, Nizpro crank girdle, Billet oil pump
Power adder: Custom tuned by Gentech, CAPA flashbox
  • Member For: 15y 10m 12d
I was just in a tire fryer today 365rwkw and manual .. wow.. 1 ==== 2=== 3== 4= got mine booked in for a tune but congrats goes to the guys pulling over 360 that's serious power..
  • Member For: 16y 5m 26d
Car: 05 BA MKII
TRANS:T56 Mal Wood opt3 and shifter
Boost:15lb
Induction:ss wide mouth K&n flat panel filter,Dekas 60 LB,intank Walbro
Turbo:stock 12lb actuator
Exhaust:xforce 4" dump,hi flow cat,31/2 full stainless system
Internals:stock, nizpro cobra valve springs
Power:306.7rwkw/882 n/m of torque
Intercooler: f6
Edited by envyxr
  • Member For: 16y 1m 7d
Car: 04 BA XR6 Turbo
Transmission: 4 Speed Auto / Aftermarket Trans Cooler
Power: 293.9rwkw
Boost: 15Psi
Induction: stock pipes/cross over,Pod Filter
Turbo: Stock turbo 12 Psi Actuator
Valve springs: Cobra Valve Springs
Exhaust: 3.5 Inch Dump, 3 Inch high flow cat
Fuel pump: Walbro 341
Intercooler: Monza
Injectors: KPM Blue Print High Flowed
Power adder: Custom tuned by Heinrich Performance & Tuning
About a month ago I was looking at this topic and writing down things that I needed to get in instal order so then I can fit them without needing a tune.. like Cooler then fuel pump then High flow cat.. thanx for these details saved me over 2k in mods by collecting the items my self..
Car: 07 BF II XR6 Turbo
Transmission: ZF6 Speed Auto
Power: 342.6rwkw - 459rwhp
Boost: 18Psi
Induction: stock pipes/cross over with stock airbox + K&N and F6 CAI 2nd intake
Turbo: Stock turbo 12.7 Psi Actuator
Valve springs: BF II
Exhaust: 4.5" xForce Highflow Cat The rest Stock
Intercooler: Monza
Injectors: Deka 60lb
Power adder: Sniper Tune box By BPT Motorsport PERTH
Edited by GMKILLER
  • Member For: 17y 4m 10d
Car: 03 BA Sedan
Transmission: 4 Spd
Power: 265rwkw
Boost: 13psi
Induction: F6 Snorkel, K&N Filter
Turbo: Stock
Valve springs: Nizpro
Exhaust: Full X-Force 3.5inch split dump pipe, 4 inch cat, into twin 2.5 inch cat back system
Intercooler: F6 Cooler
Injectors: 60lb Siemens Flow matched
Power adder: Elite Automotive
Edited by berzerker
  • 3 weeks later...
  • Member For: 16y 7m 5d
  On 10/12/2008 at 6:52 AM, Marc17 said:
car: BF MKI XR6T (12/05)
trans: 6 speed auto
power: 308rwkw (valve springs starting to give in)
boost: 13psi
induction: process west stage1 cooler with f6 cai snorkle and K&N Performance Air Filter
turbo: stock
valve springs: stock
exhaust: xforce 4inch dump into 3.5inch single
fuel system: Blueprint 44lbs Injectors
tune: CAPA Ford Flasher Box with KPM Edit Customized tunes on Dyno Including Transmission Upgrade
hoping for high 11's at the strip next week
will be getting valve spring package in the near future
Edited by Marc17
  • 2 months later...
  • Member For: 16y 4m 1d
Car: BF MKI XR6 Turbo
Trans: ZF 6 Sp Auto
Power: 380.4 RwKw
Boost: 16psi
Induction: Modified Airbox, Nizpro Silver cooler, larger piping, polished coolside, upgraded turbo housing and wastegate actuator
Turbo: Stock
Valve Springs: Stock
Exhaust: 4" dump, 5" cat, 3.5" system with twin 2.5" tips
Fuel: Bosch 044 700hp pump, surge tank, Nizpro 700cc injectors
Power adder: Tune with XCal3 Unit by the magicians at Tunehouse
:clap:
