Adrian6T T.P.I.S. Donating Members 2,578 Member For: 19y 11m 11d Gender: Male Location: SoR, WA Posted 16/12/08 04:38 AM Share Posted 16/12/08 04:38 AM Name: AdrianCar: BF II F6 TornadoTrans: 6 speed AutoPower: 299.7rwkwBoost: 12psiInduction: StockTurbo: StockValve Springs: StockExhaust: 4" SMB Dump and Cat. Stock system.Fuel system: Seimens Deka's & Walbro pumpTune: MonstaTorque Link to comment Share on other sites More sharing options...
Guest Guests Posted 16/12/08 05:28 AM Share Posted 16/12/08 05:28 AM (edited) Name: DeanCar: BF II F6 TyphoonTrans: 6 speed AutoPower: 409rwkwBoost: 18psiInduction: Nizpro plenum, Nizpro Cooler, Nizpro 4"intakeTurbo: GT3582r with ported wastegate & flapper mod, 12psi actuatorValve Springs: StockExhaust: 4" SMB turbo back system with 5" catFuel system: Seimens Deka's, Walbro pump & surge tank/044 being fabricated atmTuner: MonstaTorque Edited 16/12/08 05:29 AM by 03XR6T Link to comment Share on other sites More sharing options...
Ryan Donating Members 235 Member For: 16y 10m 5d Gender: Male Location: Sydney Posted 16/12/08 05:45 AM Share Posted 16/12/08 05:45 AM Name: RyanCar: BA mk1 Trans: T5Power: 304rwkwBoost: 6psi spiking to 12psi and tapering offInduction: rapid 4" intake, 3" high flow cooler kit, hot & cold pipesTurbo: StockValve Springs: NIZPROExhaust: stock dump, 3.5" metal cat, 3.5" to twin 2 1/4", twin hot dogs and cannonsFuel system: stock (DEKA's to go in maybe surge tank also)Tuner: CV Performance Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 16y 9m 26d Gender: Male Posted 16/12/08 09:29 AM Share Posted 16/12/08 09:29 AM micbfxr6t ute manualpw st3 coola, plenum, 60lb, walbro pump, nizpro valve sp, single 3.5 inch ex with 1 straight thru muffler, 6boost high mount manifold, replacement externally gated exhaust housing with external gate mounted off with screamer (etm), custom 3.5 inch dump and valeo ceramic clutch, pedders lowered springs all round.500.5rwhp@15.8psi on pump.tuned by the best:elite auto. Link to comment Share on other sites More sharing options...
Strike_Lightning Strike_Lightning Donating Members 198 Member For: 18y 7m 21d Gender: Male Location: Warnbro WA Posted 21/04/09 10:56 AM Share Posted 21/04/09 10:56 AM name - Davecar - 04 BA MK1 transmission - T56power - 267rwkwboost - 12psiinduction - extra typhoon cai, k+n filter, wog cooler and hot side pipesturbo - stockvalve springs - stockexhaust - smb high flow cat, centre mufflers replaced with hot dogsfuel - deka injectors and walbro fuel pumptuner - xtreme Link to comment Share on other sites More sharing options...
F6RD Donating Members 249 Member For: 16y 2m 9d Gender: Male Posted 21/04/09 11:29 AM Share Posted 21/04/09 11:29 AM (edited) Name: Sabastian (Baz)Car: BA 03 XR6TTrans: AutoPower: 262.9rwkwBoost: 13psiInduction: Typhoon box, xr8 intake, K&N FilterTurbo: Stock, ported turbo housing, 12 psi actuatorIntercooler: PWR cooler existing piping, plazmeman under battery pipeValve springs: StockExhaust: 3.5 XForce cat centre muffler removedFuel system: Walbro fuel pumP, Seimens 60lbTune: Pitlane Edited 21/04/09 11:31 AM by F6RD Link to comment Share on other sites More sharing options...
whistler6 Member 417 Member For: 17y 2m 15d Gender: Male Location: VIC Posted 05/06/09 09:46 AM Share Posted 05/06/09 09:46 AM Name: JamesCar: BF 08 XR6T sedanTrans: ZFPower: 349.6Boost: 16psiInduction: Rapidsystems 4'' intake/alloy airboxTurbo: Stock, ported wastegate, flapper valve, 12 psi actuatorIntercooler: Rapidsystems V3 cooler kit, 3'' cold side, 2.5'' hot side pipingValve springs: StockExhaust: Rapidsystems - 4'' stainless dump, 5'' stainless cat, 3.5'' exhaustFuel system: Process West surge tank/044 pump, Siemens 60'sTune: Mick @ Pit Lane Performance Link to comment Share on other sites More sharing options...
Baddy Member 55 Member For: 17y 2m 19d Posted 07/06/09 12:23 PM Share Posted 07/06/09 12:23 PM Just been reading through this thread, looks like the standard exhaust with a cat change will flow big numbers. A few guys are running 15psi, that's great for a factory exhaust!! Link to comment Share on other sites More sharing options...
dazxr6t Member 11 Member For: 17y 3m 10d Posted 08/06/09 05:06 AM Share Posted 08/06/09 05:06 AM ba xr6tk&nhigh flow metal catseimens 60 lb injectorsflash tune (custom)typhoon front 1/2 stock exhaustnizpro valve springsstock intercoolerstock plumbing230.5 kw at 5100 at the wheels BUT 780 nm torque at the wheels at 2100PLEASE EXPLAINpiss poor power but massive torque. goes pretty well but not the power I was after or what it should have for the mods. think they must have put a kenworth truck engine in there by mistake. still beats most things around but should have about 300+ for that amount of torque I would think 1 Link to comment Share on other sites More sharing options...
Baddy Member 55 Member For: 17y 2m 19d Posted 09/06/09 10:03 AM Share Posted 09/06/09 10:03 AM I'd say that you get your max power instantly, then it's just a flat curve to redline? Sounds like something is stopping you from getting more power in the top end. Maybe get a 12psi actuator, so it holds more boost up top. Link to comment Share on other sites More sharing options...
