XsiV Member 6 Member For: 17y 6m 3d Gender: Male Posted 11/09/07 03:11 AM Share Posted 11/09/07 03:11 AM (edited) Ive been reading many posts and come up with the following mods...InjectorsFuel Pump3" Dump Pipe and High Flow Cat - stock exhaust remains stockReplacement FMICCustom TuneIve seen many people recommending new valve springs... Whats the reason for this? If I go down the track of valve springs, would it be benefical doing the cam at the same time to reduce labour costs??P.S. I got an auto, and looking at having the gear changes shortened. Edited 11/09/07 03:13 AM by XsiV Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 7m 14d Gender: Male Posted 11/09/07 03:39 AM Share Posted 11/09/07 03:39 AM the stock dump is 3" so its not worth replacing it with another of the same size. aps dont change the dump in their kits iirc, and there are cars running over 400rwkw with the stocker.the stock valve springs are too soft and you can get valve float. with a high flow cat sometimes you can get by without changing them.its not really necessary to change the cam, ppl are running over 500rwkw with the stock cam im pretty sure. sounds mean as with one but! Link to comment Share on other sites More sharing options...
XsiV Member 6 Member For: 17y 6m 3d Gender: Male Posted 11/09/07 04:13 AM Share Posted 11/09/07 04:13 AM Ah ok! I didnt realise the stock dump pipe was 3 inch. Cool, many people have suggested that the stock exhaust flows enough and only to replace the cat with a high flow. Is this good advise?So I can look at replacing the valve springs and leaving the dump pipe stock, and with the above mods should be happy! Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 7m 14d Gender: Male Posted 11/09/07 06:45 AM Share Posted 11/09/07 06:45 AM that sounds like a winner Link to comment Share on other sites More sharing options...
iTec TEAM BA Donating Members 1,755 Member For: 20y 1m 29d Gender: Male Location: North of The Bridge Posted 11/09/07 07:01 AM Share Posted 11/09/07 07:01 AM in a sedan I would not do the intank pump, Put a surge tank and pump in and leave the factory intank pump... you will get mad fuel surge at about 300rwkw so you might as well do it propperly the first time... it will end up saving you money in the long run... utes dont seem to suffer the same problem as much but it is still something to consider. Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 8m 17d Gender: Male Location: Sydney NSW Posted 11/09/07 09:14 AM Share Posted 11/09/07 09:14 AM in a sedan I would not do the intank pump, Put a surge tank and pump in and leave the factory intank pump... you will get mad fuel surge at about 300rwkw so you might as well do it propperly the first time... it will end up saving you money in the long run... utes dont seem to suffer the same problem as much but it is still something to consider. Yes good advise... a surge tank and 044 is much safer than just a Walbro intake Link to comment Share on other sites More sharing options...
bzerkone Member 132 Member For: 17y 7m 21d Gender: Male Location: Perth Posted 11/09/07 09:21 AM Author Share Posted 11/09/07 09:21 AM in a sedan I would not do the intank pump, Put a surge tank and pump in and leave the factory intank pump... you will get mad fuel surge at about 300rwkw so you might as well do it propperly the first time... it will end up saving you money in the long run... utes dont seem to suffer the same problem as much but it is still something to consider.I have a ute so your saying I may not need the surge tank? or I will need one? :fear (5): cheers Link to comment Share on other sites More sharing options...
iTec TEAM BA Donating Members 1,755 Member For: 20y 1m 29d Gender: Male Location: North of The Bridge Posted 12/09/07 05:08 AM Share Posted 12/09/07 05:08 AM I have a ute so your saying I may not need the surge tank? or I will need one? cheersjust from what others have done it seems not to be as big an issue in the utes because the tank is different... personaly if it was my choice I would choose the surge over an intank just to stay on the safe side. Link to comment Share on other sites More sharing options...
