Stupid Question
Woggymobster
  • Member For: 17y 9m 12d
It is possible to up the boost with out a edit. I was thinking of using
a manual boost controller to by pass the electric boost selinoid.
And at what boost does the computer see it at being overboost.
Thanks for any input
  • Member For: 17y 8m 11d
Don't waste your time mate, get a proper edit and you won't have dramas later
  • Member For: 18y 10m 12d
its not really a case of what boost pressure it stops at, if the computer senses that it cant alter the boost on a percentage of times calculated on a scale it says ,no thanks,
it uses 2 boost sensors and many people have tried to fool the computer.
I have read articles from back when the t first came out saying that you can get away with a few psi using 2 bleed valves but the computer still figured it out and said no after the secondary system picked up more power from the gearbox torque tags.
