groper Member 611 Member For: 18y 3m 15d Posted 05/09/07 12:08 PM Share Posted 05/09/07 12:08 PM I was wondering how to go about temporarily disabling the ABS system for a skid competition coming up... I think I read a while back but cant remember, that if you jack up the car and spin a wheel before turning the key, the car thinks it has a faulty wheel sensor and so switches teh ABS off... can anone confirm if this works? Link to comment https://www.fordxr6turbo.com/forum/topic/38061-how-to-temporarily-disable-abs/ Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 21d Gender: Male Location: Victoria Posted 05/09/07 12:26 PM Share Posted 05/09/07 12:26 PM Try pulling the ABS fuse.That will probably make the warning light come on but I think it would disable the system. Link to comment https://www.fordxr6turbo.com/forum/topic/38061-how-to-temporarily-disable-abs/#findComment-571732 Share on other sites More sharing options...
Guest Guests Posted 05/09/07 08:47 PM Share Posted 05/09/07 08:47 PM If the car is off how is it going to know it's got a faulty sensor Link to comment https://www.fordxr6turbo.com/forum/topic/38061-how-to-temporarily-disable-abs/#findComment-571828 Share on other sites More sharing options...
xf_turbo Member 45 Member For: 18y 3m 7d Gender: Male Location: Adelaide Posted 05/09/07 11:08 PM Share Posted 05/09/07 11:08 PM Just pull the ABS fuse, dont worry its safe to do so. Link to comment https://www.fordxr6turbo.com/forum/topic/38061-how-to-temporarily-disable-abs/#findComment-571857 Share on other sites More sharing options...
TOM1111 Member 631 Member For: 17y 9m 18d Gender: Male Location: newcastle Posted 06/09/07 04:40 AM Share Posted 06/09/07 04:40 AM fuse would be the easiest way Link to comment https://www.fordxr6turbo.com/forum/topic/38061-how-to-temporarily-disable-abs/#findComment-571961 Share on other sites More sharing options...
ToXic BF Beast New Member 18 Member For: 10y 6m 19d Gender: Male Location: Dee Why Posted 01/11/14 07:08 AM Share Posted 01/11/14 07:08 AM My TCS light came on permanently & brakes were spazzing out every time I came to a slow stop or crawling in traffic(prob wheel sensor, brake pedal switch)I just pulled the ABS fuse out and goodbye clunk.! However, now I obviously have no TC & DSC.. Which is fine. But how bad is it drive without ABS? Not track just road drivingNot to mention the 3 new warning lights - The scary red exclamation mark. Link to comment https://www.fordxr6turbo.com/forum/topic/38061-how-to-temporarily-disable-abs/#findComment-1509608 Share on other sites More sharing options...
luke187 Member 297 Member For: 11y 5m 10d Posted 03/11/14 07:46 AM Share Posted 03/11/14 07:46 AM (edited) Lift up the bottom part of the rear seat and disconnect one of the sensors there. You'll get an abs and traction control light but neither will work until its re-connected and you still get to keep your speedo. Takes 30secs. Edited 03/11/14 07:47 AM by luke187 Link to comment https://www.fordxr6turbo.com/forum/topic/38061-how-to-temporarily-disable-abs/#findComment-1510066 Share on other sites More sharing options...
BeerTurbo Donating Members 241 Member For: 7y 8d Posted 26/01/22 09:58 AM Share Posted 26/01/22 09:58 AM Hey, I did this, but lost speedo. Also after roughly 1 min the car went into a limp mode with a lower limiter. Abs is not overly helpfull on dirt tracks with rally tire's. Link to comment https://www.fordxr6turbo.com/forum/topic/38061-how-to-temporarily-disable-abs/#findComment-1710210 Share on other sites More sharing options...
