senna_T Forged Member Lifetime Members 15,818 Member For: 18y 3m Gender: Male Location: SW Sydney Posted 05/09/07 12:35 AM Author Share Posted 05/09/07 12:35 AM not sure really, I'd say with the right crossover we could get close to the 350rwkw mark, I'd be more than happy with that! Link to comment https://www.fordxr6turbo.com/forum/topic/38027-engine-build/page/2/#findComment-571463 Share on other sites More sharing options...
GreenXR6T Donating Members 630 Member For: 19y 8m 5d Gender: Male Location: NSW Posted 05/09/07 04:21 AM Share Posted 05/09/07 04:21 AM Interesting and well done.What pistons (1st oversize?) and rods are you going to use? Has the crank been ground? Link to comment https://www.fordxr6turbo.com/forum/topic/38027-engine-build/page/2/#findComment-571534 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 3m Gender: Male Location: SW Sydney Posted 05/09/07 04:27 AM Author Share Posted 05/09/07 04:27 AM Hey, I'm using the Atomic Rods, and the Atomic/Mahle pistons which are a standard size with a very slight over bore of 0.015, so they basically need a file for clearanceI gave the machine shop my block, head and crank, I think he's just checking to make sure the crank is completely balanced or whatever else he can think of! Link to comment https://www.fordxr6turbo.com/forum/topic/38027-engine-build/page/2/#findComment-571535 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 14d Gender: Male Location: Perth Posted 05/09/07 04:36 AM Share Posted 05/09/07 04:36 AM Why did you have to remove the ECM? You can swing the ac compressor out of the way and cable tie it so you dont have to depressuriss the system. It pretty cool (and nerve racking) when you swing the new donk in and fire it up for the first time!!good luck mate Link to comment https://www.fordxr6turbo.com/forum/topic/38027-engine-build/page/2/#findComment-571540 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 3m Gender: Male Location: SW Sydney Posted 05/09/07 04:42 AM Author Share Posted 05/09/07 04:42 AM You mean the A/C compressor lines? yeah, if I'd known that I would've done it! I had my service guys take the A/C gas out before I did the work, its something like a $100,000 fine if you vent the gas to atmo! Link to comment https://www.fordxr6turbo.com/forum/topic/38027-engine-build/page/2/#findComment-571541 Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 19y 1m 13d Gender: Male Location: nsw Posted 05/09/07 05:52 AM Share Posted 05/09/07 05:52 AM if your looking for a xover and a pipe from your pwr cooler the plazmaman stg 2 piping kit should fit.looking at this pic the pipe from the cooler can be shortened to fit the pwr and its the same size from the cooler to the tb.you have an airfilter already so you only need one part of the kit.they also have a hot side kit from the turbo to the cooler and looking at the similar size of the pwr cooler to mine, it should fit too.hope this helps. Link to comment https://www.fordxr6turbo.com/forum/topic/38027-engine-build/page/2/#findComment-571551 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 3m Gender: Male Location: SW Sydney Posted 05/09/07 06:07 AM Author Share Posted 05/09/07 06:07 AM (edited) thanks for the heads up mate, I also have PWR's 'round battery pipe, which sits in a slightly different spot than the normal return pipe, this is whats stopped me from getting one of these kits already! I think I'll go and see plazmaman when the car gets back on the road!Cheers,Pat Edited 05/09/07 06:07 AM by senna_T Link to comment https://www.fordxr6turbo.com/forum/topic/38027-engine-build/page/2/#findComment-571556 Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 22y 4m 14d Gender: Male Location: Brisbane Posted 05/09/07 08:43 AM Share Posted 05/09/07 08:43 AM It's all looking good. Can't wait to see what you get Link to comment https://www.fordxr6turbo.com/forum/topic/38027-engine-build/page/2/#findComment-571606 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 3m Gender: Male Location: SW Sydney Posted 05/09/07 11:23 AM Author Share Posted 05/09/07 11:23 AM (edited) well guys, I'm off work tomorrow thanks to the monster flu strain going around! First things first, I have to help a mate swap turbos on his skyline (he had an issue with the size of mine campared to the size of his!)Then around 4pm I'll pick up the block from westend performance and start putting it all back together!I'm excited, can you tell? Edited 05/09/07 11:24 AM by senna_T Link to comment https://www.fordxr6turbo.com/forum/topic/38027-engine-build/page/2/#findComment-571664 Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 22y 4m 14d Gender: Male Location: Brisbane Posted 05/09/07 11:42 AM Share Posted 05/09/07 11:42 AM You are keen considering you have the flu but I can't say I blame you Link to comment https://www.fordxr6turbo.com/forum/topic/38027-engine-build/page/2/#findComment-571681 Share on other sites More sharing options...
