Engine Build
senna_T
  • Forged Member
  • Member For: 17y 11m 23d
not sure really, I'd say with the right crossover we could get close to the 350rwkw mark, I'd be more than happy with that!
  • Replies 46
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
  • Forged Member
Hey, I'm using the Atomic Rods, and the Atomic/Mahle pistons which are a standard size with a very slight over bore of 0.015, so they basically need a file for clearance
I gave the machine shop my block, head and crank, I think he's just checking to make sure the crank is completely balanced or whatever else he can think of!
  • Moar Powar Babeh
  • Member For: 19y 4m 7d
Why did you have to remove the ECM? You can swing the ac compressor out of the way and cable tie it so you dont have to depressuriss the system. It pretty cool (and nerve racking) when you swing the new donk in and fire it up for the first time!!
good luck mate
  • Forged Member
You mean the A/C compressor lines? yeah, if I'd known that I would've done it! I had my service guys take the A/C gas out before I did the work, its something like a $100,000 fine if you vent the gas to atmo!
  • Member For: 18y 10m 6d
if your looking for a xover and a pipe from your pwr cooler the plazmaman stg 2 piping kit should fit.
looking at this pic the pipe from the cooler can be shortened to fit the pwr and its the same size from the cooler to the tb.
you have an airfilter already so you only need one part of the kit.
they also have a hot side kit from the turbo to the cooler and looking at the similar size of the pwr cooler to mine, it should fit too.
hope this helps.
  • Forged Member
thanks for the heads up mate, I also have PWR's 'round battery pipe, which sits in a slightly different spot than the normal return pipe, this is whats stopped me from getting one of these kits already! I think I'll go and see plazmaman when the car gets back on the road!
Cheers,
Pat
Edited by senna_T
  • Forged Member
well guys, I'm off work tomorrow thanks to the monster flu strain going around!
First things first, I have to help a mate swap turbos on his skyline (he had an issue with the size of mine campared to the size of his!)
Then around 4pm I'll pick up the block from westend performance and start putting it all back together!
I'm excited, can you tell?
Edited by senna_T
