XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 3m 25d Gender: Male Location: Perth, NOR Posted 04/09/07 06:48 AM Share Posted 04/09/07 06:48 AM removing the BOV or blocking the thin vacuum line should have the exact same effect, and your car will dose. A car pushing out 10+PSI will dose more than a stock one obviously Link to comment Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 6m 15d Gender: Male Location: NSW Posted 04/09/07 07:01 AM Share Posted 04/09/07 07:01 AM http://www.fordxr6turbo.com/forum/index.php?showtopic=24608the link is in my post (#13) in this thread, its been made a sticky in the bov workshop forum Thanks Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 10d Gender: Male Location: Perth Posted 04/09/07 07:09 AM Share Posted 04/09/07 07:09 AM removing the BOV or blocking the thin vacuum line should have the exact same effect, and your car will dose. A car pushing out 10+PSI will dose more than a stock one obviously If you remove the vacum line the BOV will open and vent once the pressure inside the intake manifold becomes positive. You need pressure in this line to hold the bov closed until you close the throttle. Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 7m 25d Gender: Male Location: OZ Posted 04/09/07 07:55 AM Share Posted 04/09/07 07:55 AM If you remove the vacum line the BOV will open and vent once the pressure inside the intake manifold becomes positive. You need pressure in this line to hold the bov closed until you close the throttle.Remember the std bosch valve is reverse vented so on std boost I doubt it will open as boost is acting on the side of the valve and not from underneath as on a conventional valve. I have tested this on std boost and put a pod filter on and it dosed like hell. Having said this I wouldn't want to be driving around with the BOV on and the vac lines closed off though as there is a chance that you may leak boost as the valve sits flush and doesn't overlap... if you check inside the valve one will see what I mean. Cheers. Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 8m 10d Gender: Male Posted 04/09/07 08:01 AM Share Posted 04/09/07 08:01 AM what did you do with the small pipe that comes off one end of the bov adrian?block that one too? Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 7m 25d Gender: Male Location: OZ Posted 04/09/07 08:08 AM Share Posted 04/09/07 08:08 AM One (I repeat one) of the benefits of a BOV was suppossed (I repeat suppossed) to reduce lag between gear changes because the turbo was allowed to keep spooling (read a Turbosmart website thingy). However been in cars with no BOV myself I actually agree with Adrian on this now. I am yet to see a damaged turbo as a result of not running a BOV. BOV on the Turbo 6 is basically designed to keep noise to a minimum and being reverse vented it also lets air bypass the turbo when cruising and at idle (under vacuum situations) therefore theoretically lowering fuel consumption. I think it's now safe to say that removing the factory BOV will not damage your turbo. Same as not letting your car idle for a minute after driving (ok thrashing probably a different story with the idle). Some good info of your experience Adrian, cheers PS regardless of the BOV debate if you don't want lag between gearchanges..... FLATSHIFT. It will take two 10th's of ya 1/4 mile times Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 7m 25d Gender: Male Location: OZ Posted 04/09/07 08:13 AM Share Posted 04/09/07 08:13 AM what did you do with the small pipe that comes off one end of the bov adrian?block that one too?Bin lol!!!When I did this for a test I just got a thin silicon tube and kinked it good and proper and cable tied it back onto the thin metal vacuum pipe. Probably get a bit of silicon tube (even use the original) and cable tie it to the metal and then block the other end with something and cable tie that so it doesn't leak. Link to comment Share on other sites More sharing options...
groper Member 611 Member For: 18y 1m 4d Posted 04/09/07 10:00 AM Share Posted 04/09/07 10:00 AM so we have people saying is helps lag and some who say it doesnt... damn, looks like im gonna have to try this myself...ive read simon from nispro write up on BOV`s, and I agree with alot of it and disagree with some of it too. It baffles me why garrett themselves promote the use of BOV`s (look up thier web site) and yet somone as clued up as simon can say the opposite???who to believe??? nispro or garrett? both have proven their expertise in their field... Link to comment Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 20y 3m 2d Gender: Male Location: SoR, WA Posted 04/09/07 10:01 AM Author Share Posted 04/09/07 10:01 AM what did you do with the small pipe that comes off one end of the bov adrian?block that one too?Plugged my boost gauge straight up to the fitting instead of running a T piece. Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 9m 7d Gender: Male Location: Melbourne Posted 04/09/07 10:04 AM Share Posted 04/09/07 10:04 AM so we have people saying is helps lag and some who say it doesnt... damn, looks like im gonna have to try this myself...ive read simon from nispro write up on BOV`s, and I agree with alot of it and disagree with some of it too. It baffles me why garrett themselves promote the use of BOV`s (look up thier web site) and yet somone as clued up as simon can say the opposite???who to believe??? nispro or garrett? both have proven their expertise in their field...Yeah and they both don't have products to push so whats the go?? Yay or Nay????? Link to comment Share on other sites More sharing options...
