Smoke them tyres Member 557 Member For: 17y 4m 9d Gender: Male Location: Brisbane Posted 05/01/08 12:10 AM Share Posted 05/01/08 12:10 AM Any idea on metal spec used (re durability?) Link to comment https://www.fordxr6turbo.com/forum/topic/37890-exhaust-manifold/page/4/#findComment-617287 Share on other sites More sharing options...
Muzza No V6 for me thanks!! Donating Members 583 Member For: 19y 8m 24d Location: Newcastle Posted 05/01/08 10:41 PM Share Posted 05/01/08 10:41 PM Looks the goods,dam now I got too start saving more $$.Muzza. Link to comment https://www.fordxr6turbo.com/forum/topic/37890-exhaust-manifold/page/4/#findComment-617577 Share on other sites More sharing options...
fordboy1981 Donating Members 2,075 Member For: 22y 3m 12d Gender: Male Location: Sydney, NSW Posted 07/01/08 01:10 AM Share Posted 07/01/08 01:10 AM what difference does a single and double entry manifold make? Link to comment https://www.fordxr6turbo.com/forum/topic/37890-exhaust-manifold/page/4/#findComment-617899 Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 4m 6d Gender: Male Location: Sydney Posted 07/01/08 01:43 AM Share Posted 07/01/08 01:43 AM what difference does a single and double entry manifold make?Twin/double/dual entry will spool up better. The focus is to have 2 sets of exhaust gas pulses, and the avoidance of gas interference and conflict from one side to the other.Brian Link to comment https://www.fordxr6turbo.com/forum/topic/37890-exhaust-manifold/page/4/#findComment-617902 Share on other sites More sharing options...
fordboy1981 Donating Members 2,075 Member For: 22y 3m 12d Gender: Male Location: Sydney, NSW Posted 07/01/08 02:05 AM Share Posted 07/01/08 02:05 AM Twin/double/dual entry will spool up better. The focus is to have 2 sets of exhaust gas pulses, and the avoidance of gas interference and conflict from one side to the other.Brianbut I presuming they either cost more or don't have the same top end? Link to comment https://www.fordxr6turbo.com/forum/topic/37890-exhaust-manifold/page/4/#findComment-617906 Share on other sites More sharing options...
ETM Member 1,194 Member For: 18y 1m 17d Gender: Male Location: syd south Posted 07/01/08 04:20 AM Share Posted 07/01/08 04:20 AM twin scroll turbine housings are said to spool faster but in real life you would be lucky if you could notice the difference.they are also much harder to achieve a perfect wastegate feed setup,space becomes more of an issue.generally I like an open housing every time.id rather suffer a tiny bit more lag (which can be more than reversed with a good manifold) and have excellent boost control than the other way around Link to comment https://www.fordxr6turbo.com/forum/topic/37890-exhaust-manifold/page/4/#findComment-617931 Share on other sites More sharing options...
Smoke them tyres Member 557 Member For: 17y 4m 9d Gender: Male Location: Brisbane Posted 07/01/08 01:06 PM Share Posted 07/01/08 01:06 PM metal spec? 304 stainless? other? Link to comment https://www.fordxr6turbo.com/forum/topic/37890-exhaust-manifold/page/4/#findComment-618118 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 1m Gender: Male Posted 08/01/08 01:40 PM Share Posted 08/01/08 01:40 PM (edited) unless back to back testing is done its hard to say how much benefit a twin scroll gives.The main reason I started using them was to minimise gas reversion and detonation on a log manifold. I think it did its job well.I have built split tubular manifolds but think the benefits are less due to reversion being more difficult because of the long runners so maybe its not as necessary. And its much greater pain in the ass to make as IMO you must keep it split to the wastegate so theres only 40thou gap to the w/g valve for it to work properlyThere must be a reason why garret has made the TO4Z in split pulse turbineI make mine in 316 stainless 3mm wall thickness with steel flanges Edited 08/01/08 01:42 PM by turbotrana Link to comment https://www.fordxr6turbo.com/forum/topic/37890-exhaust-manifold/page/4/#findComment-618489 Share on other sites More sharing options...
