Falchoon I see red Member 5,758 Member For: 22y 8d Location: nowhere in particular Posted 01/09/07 06:10 AM Share Posted 01/09/07 06:10 AM Anything from $1.5K to $5K or more, depending on who is doing it and what needs doing. Link to comment Share on other sites More sharing options...
XR6IXT Donating Members 662 Member For: 19y 4m 3d Gender: Male Location: Adelaide Posted 01/09/07 06:33 AM Share Posted 01/09/07 06:33 AM fark that's a nice ride. Do you know what wheels they are?They are zenetti kaotics Link to comment Share on other sites More sharing options...
Muzza No V6 for me thanks!! Donating Members 583 Member For: 19y 4m 19d Location: Newcastle Posted 01/09/07 06:36 AM Share Posted 01/09/07 06:36 AM I was looking into the C4 and Turbo 400 and spoke to Protrans Keas and Al's Race glides and they all recommended a Turbo 400 because it would handle alot more power. They all seemed to think that the C4 would not last long.You can get a overdrive for the C4's and Turbo 400's there around 3K but you get four gears so great for highway runs. Both boxes are similar money but the Turbo 400 is the way to go.I think your spot on what your saying. The Turbo 400 is proven to handle more then most can give it. I didn't realize the do an overdrive for then but if they do it would make a perfect box.Muzza Link to comment Share on other sites More sharing options...
dansedgli Member 214 Member For: 20y 11m 14d Posted 01/09/07 07:07 AM Share Posted 01/09/07 07:07 AM http://www.gearvendors.com/hrgm3s.html Link to comment Share on other sites More sharing options...
MYWPN Donating Members 554 Member For: 19y 5m 24d Gender: Male Location: Bendigo Posted 01/09/07 08:13 AM Share Posted 01/09/07 08:13 AM A properly built c10 will never fail you, they have been proven time and time again over time, Ive been told bob grant auto's garantee there c10 will take 1000hp, street or strip, written garantee Link to comment Share on other sites More sharing options...
Guest Guests Posted 02/09/07 11:58 AM Share Posted 02/09/07 11:58 AM A properly built c10 will never fail you, they have been proven time and time again over time, Ive been told bob grant auto's garantee there c10 will take 1000hp, street or strip, written garanteedon't take my word for it here is a quote:The Ford C4 and C6 transmissions are two of the best performing, most durable transmission ever built. By adding a Gear Vendors Under/Overdrive to these transmissions you have an unbeatable package far superior to any factory overdrive automatic and with 6 close ratio gears for performance.With a 28.6% faster cruising gear your 4.10 rear gears will give you the same net rpm as a set of 3.20s (3.55s will cruise like 2.77s - see Final Drive Ratios. Your engine will turn the same revs it does now in 500 miles but take you 640 miles. Fuel economy will jump 22-28% on a normally aspirated engine and even greater on forced induction powerplants.you have c4's weakest, c9 in da middle and c10 stongest.c10 internals fit c4&9 cases6 pinion gears, special pistons, clutch drums are all requred and more for a proper build!there is also 4spd box using c series bellhousings but have proved to hard to source!c series box's can be built to handle over 1500hp but cost lots as icemybutt said! Link to comment Share on other sites More sharing options...
Guest Guests Posted 02/09/07 11:59 AM Share Posted 02/09/07 11:59 AM I think your spot on what your saying. The Turbo 400 is proven to handle more then most can give it. I didn't realize the do an overdrive for then but if they do it would make a perfect box.Muzzagranted t400's can be built to handle more than c series but the total installed cost for an equivelent box is much more! Link to comment Share on other sites More sharing options...
Guest Guests Posted 02/09/07 12:03 PM Share Posted 02/09/07 12:03 PM the chrysler 727 box is equally as strong as a powerglyde and only rivaled by the c6 which is possibly 50% stronger than the t400 Link to comment Share on other sites More sharing options...
XR6Turbo22 Member 86 Member For: 17y 4m 3d Gender: Male Location: Melbourne Posted 27/09/07 12:58 PM Author Share Posted 27/09/07 12:58 PM how much would it cost to rebuild a powerglide and fit it in a xr6t? Link to comment Share on other sites More sharing options...
SM DJP Member 9 Member For: 16y 2m 21d Gender: Male Location: Noble Park Posted 10/10/08 09:32 AM Share Posted 10/10/08 09:32 AM Hi all,I'm in the process of rebuilding my 4-speed in my XR6-T. I'm thinking of just sticking with the BTR and running a 2800-3500rpm stall convertor. Anyone had any experience with convertors on these 4-speeds? I've been told that the C9/C10 is alot stronger but doesnt allow tiptronic?? Any thoughts would help. Looking at spending around $3800-4500.Hey just thought I'd say the c9 can be made quite steetable and are a bit old school yes but if built right are just awsome at wot & also if the conversion is done by the right people it can be made to look very complimentry when the B&M shifter is fitted nice Eg. With the genuine shifter cover & matching leather boot.Also with the full manuel valve body you vertually have your tiptronic action feel about it.Also This conversion can be done right for around 7 grand.By the time you rebuild 2 4 speeds ( which is not uncommon ) your vertually there.But I will say fuel economy will change & vary depending on convertor size ect.Hope this helps on your decision making. Link to comment Share on other sites More sharing options...
