trevs Member 781 Member For: 18y 2m 13d Gender: Male Location: balmain Posted 19/08/07 12:25 PM Share Posted 19/08/07 12:25 PM street-legal slicks that fit the standard 17 inch rims does anybody have them on their car if so what brand how much and are they any good Link to comment https://www.fordxr6turbo.com/forum/topic/37584-street-legal-slicks/ Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 11m 27d Gender: Male Location: The 8th Dimension Posted 19/08/07 01:16 PM Share Posted 19/08/07 01:16 PM A bit of reading for you. Care of Autospeed.comDOT Legal Semi-SlicksNote that the tyres listed here are available in Australia and/or the US – it some instances, other countries may have the same tyre available under a different name. For comparative purposes, the prices quoted are for a 225/50 16 size (where possible).BF Goodrich"Hero-making traction and control come to the strip" is the catchphrase for the BF Goodrich G-Force T/A Drag Radial. With a primary focus on quarter mile performance, the G-Force T/A Drag Radial is fully street legal and features two full-width steel belts and 5.5/32 of an inch tread depth giving maximum straight-line traction and predictability. It is also reputedly "comfortable to drive to and from the strip."The new Drag Radial T/A is available in selected sizes between 14 and 18 inch.Speed Rating: Not available.UTQG Rating: 0(!)-B-C.Approximate Price: A 225/50 16 size is not available but a 255/50 16 costs around US$200.DunlopIn late 2003, Dunlop released a tarmac rally tyre which carries road legal identification. The Dunlop Motorsport Direzza 02G is designed by Dunlop race engineers and complements the existing Formula R range.The Direzza 02G uses a reduced tread depth, high stability pattern and race tyre construction and tread compound. This product has so far proven successful in various Targa rallies. It is available in sizes from 165/60 13 to 265/35 18.Another relatively new addition is the Dunlop SP Supersport. The Supersport has a greater number of tread cuts making it more suitable for street use and it is available in a selection of large diameter sizes – 17 to 19 inch.Old faithfuls, such as D98J (which is now effectively superseded but remains available in limited sizes), the D01/2J, Formula R SV98 and a wet weather version - the D93J - are also available.Formula Rs have won the Bathurst 12 Hour, the Eastern Creek 12 Hour, Targa Tasmania, three Peaks Rallies, Dutton's GP Rallies, Indy GP Rallies, the Panama Alaska Rally and more. Formula Rs are available in sizes from 165/70 10 to 255/40 17, while the Formula R SV98 comes from 195/55 15 to 265/35 18.Speed Rating/UTQG Rating: Not available.Approximate Price: Around AUD$400 for a 225/50 16 depending on model and availability.NittoA newcomer to the market is the DOT approved Nitto NT555R Extreme Drag Radial tyre. This tyre is primary designed for drag use but is quite streetable and can go more than 20,000km in normal use. NT555Rs are manufactured with a tread depth of 6/32 of an inch and use a specially formulated racing compound to provide maximum traction.Nitto NT555Rs are available in diameters 14 to 18 inch and widths from 205mm to 335mm.Speed Rating: All V rated.UTQG Rating: 300-A-AApproximate Price: A 225/50 16 size is not available but a 245/50 16 costs around AUD$300.HoosierOnly just DOT approved is the recently released Hoosier's Radial A3S05/R3S05. These tyres use dual grooves around their perimeter, are quick to warm up and are resistant to high temperature operation. They’re great for autocross, time trials and hill climbs but, given their near tread-less appearance, we’d suggest thoroughly checking out their legality before purchasing...Combined, the A3S05 and R3S05 are available in sizes from 185/60 13 to a massive 335/30 18.Speed Rating: All Z rated.UTQG Rating: 40-C-AApproximate Price: US$200KumhoVictoRacer V700 is the premium performance tyre from the Kumho range. This product is fully moulded, features a highly developed tread compound and an asymmetric pattern to provide maximum cornering power. Steering response is also outstanding thanks to the very stiff sidewalls. A tread depth of between 5 to 6/32 of an inch indicates this is extreme performance tyre.The latest DOT approved competition tyre in the Kumho range is the Ecsta V70A (aka V700).The Ecsta V70A uses Kumho's specially formulated high grip silica competition tread compound combined with a directional design that features wide tread ribs in the shoulders and intermediate tread blocks to maximise dry cornering grip. Its directional tread design also helps provide wet traction when run at full tread depth. The Ecsta V70A is moulded with 6/32 inch of tread depth in its two major circumferential grooves. The V70A is also lighter than the Victoracer and, unlike the Victoracer, you can remount the Ecsta ‘inside-out’ to extend its serviceable life.VictoRacers are available from 205/60 13s up to 315/35 17s while the Ecstas are available from 175/60 13 to 335/30 18.Speed Rating: The VictoRacers are V-rated in 13-14 inch sizes and Z-rated for 15-17 inchers. The 13 to 15 inch Ecstas carry an H, V or Z rating while larger diameter versions (16 to 18 inch) are all Z rated.UTQG Rating: 50-A-A.Approximate Price: VictoRacer US$160. A 225/50 16 size is not available in the Ecsta but a 225/50 15 costs around US$150.PirelliThe P Zero C is Pirelli's most purposeful tyre that is legal for road use - although it is mainly intended for circuit use. It features "excellent road holding near the limit, constant performances under very high speeds and a high resistance to the physical/mechanical stresses arising from circuit use". With a ZR (240 km/h) rating, the P Zero C also has an asymmetric tread design possessing extra large outer blocks to allow maximum road holding and stability in bends.In addition, there’s now the Pirelli P Zero Corsa DOT legal competition tyre. Designed for driver training schools and special event lap days, the P Zero Corsa is moulded with 6/32 inch of tread depth in its grooves and is available unshaved for use on damp tracks. It can alternatively be shaved to between 3/32 and 4/32 of an inch tread depth for use on dry tracks.P Zero Cs are available in sizes starting from 195/50 15 up to 245/45 16 while the P Zero Corsas are available from 205/50 17 to 315/30 18.Speed Rating: We believe they are all ZR rated.UTQG Rating: Not available.Approximate Price: Around US$210 for a Pirelli P Zero C. A 225/50 16 size is not available in the P Zero Cosa DOT competition tyre range but a 225/45 17 costs around US$225.YokohamaYokohama has recently released an all-new DOT legal semi-slick tyre – the Advan A048. This tyre is ideally suited for targa type road events, club sprints, lap dash events, circuit racing and club level events such as supersprints, motorkanas and hill climbs. It is also the official control tyre in a range of Australian motorsport categories including the V8 BRutes and the Production Car Championship. Tread depth is 6/32 of an inch but they should be shaved for maximum grip on a dry circuit.The older generation Yokohama A032R is also available at most performance retails. The A032R (successor to the A008 series) is a proven top performer which offers a good combination of dry and wet bitumen grip, progressive breakaway and clearly visible tread - which reduces the likelihood of being pulled over by the police for ‘bald’ tyres...The A048 is available in sizes from 205/50 15 to 315/30 18 while the A032R is available from 175/60 13 to 255/40 17.Speed Rating: In the A048s, there’s a range of H, V, W and Y speed ratings depending on size. In the A032R range, the speed rating for 60 series tyres is H, 50 series are V and 40/45 series are Z rated.UTQG Rating: 60-A-AApproximate Price: Around US$191 for an Advan A048. A 225/50 16 size is not available in the A032R range but a 235/40 17 costs US$146.BridgestoneThe Potenza RE540S and RE55S are Bridgestone's offerings. The older RE540S (which is gradually being phased out) is a directional tyre with a standard tread depth of 5.2mm and an extra-stiffened sidewall. This sidewall is rumoured to be amongst the firmest in this category of tyre and it has a reputation for excellent balance between dry and wet weather grip. The latest release RE55S (pictured) is very similar but is intended more towards dry performance and comes in larger sizes.The RE540S comes in a choice of sizes from 165/65 13 to the 205/65 15. The RE55S comes from 185/55 14 to 285/30 18.Speed Rating: In the RE540S and RE55S range, the 60 series tyres are H rated, the 50-55 series are V rated and the 35-45 series are Z rated.UTQG Rating: Not available.Approximate Price: Around AUD$300.FalkenThe Falken Azenis RT615 is this company's most appropriate road legal tyre. Although not as soft as some of the other tyres listed here, the RT615 is suitable for competition use and should deliver good grip thanks to its large tread blocks. Expect tyre life slightly better than the other tyres mentioned here.The Azenis RT615 is available most common sizes from 175/60 14 up to 315/30 18.Speed Rating: H or W depending on size.UTQG Rating: 200-A-A.Approximate Price: US$120ToyoToyo's most popular DOT approved competition radial is the Proxes RA-1.Designed for "touring racing" and carrying CAMS approval, it uses steel wire reinforced sidewalls, an aggressive directional tread pattern with a 8/32 inch (6.35mm) depth for exceptional wet weather traction. It can also be shaved to improve dry weather lap times. Internally, the RA-1 features two wide steel belts, jointless edge and cap construction as well as a special tread compound to optimise adhesion and durability. In this segment, the RA-1 is also quite long lasting.In addition, you can now find the Toyo Trampio R1-R which is a unique hybrid ultra high-performance/race tyre designed for club motor sport competitors that regularly use their vehicles on public roads. Due to its aggressive tread pattern and tread depth, the Trampio R1-R is particularly effective for hill climbs and lap dash events on wet or dry tarmac. The original tread depth is up to 7mm but Toyo recommend shaving it to 2 – 3.5mm for maximum dry performance.Click for larger imageAnother new addition is the Toyo Proxes R888. The R888 has a low-void ratio for minimised tread squirm on dry tracks while the new groove design optimise's water drainage from the contact patch. Round tread shoulders are also employed for progressive turn-in. This tyre provides competitive performance for a wide range of motorsport disciplines from hill climbs to endurance racing.The Proxes RA-1 is available in a reasonable range of sizes from 185/60 13 to 335/30 18. The Trampio R1-R is available in only 16 and 17 diameters. Proxes R888s are available from 185/60 13 to 295/30 18.Speed Rating: The smaller RA-1s up to 225/50 14 are V rated, while the larger sizes are Z rated. The R1-Rs are V rated while the majority of Proxes R888 are Z ratedUTQG Rating: The RA-1 is listed at 40-A-A but we are unable to find UTQG data on the Trampio R1-R and Proxes R888.Approximate Price: AUD$310 Link to comment https://www.fordxr6turbo.com/forum/topic/37584-street-legal-slicks/#findComment-565761 Share on other sites More sharing options...
trevs Member 781 Member For: 18y 2m 13d Gender: Male Location: balmain Posted 19/08/07 02:40 PM Author Share Posted 19/08/07 02:40 PM thanks good read so does anybody have any of these fitted to their car if so which ones and what did you think Link to comment https://www.fordxr6turbo.com/forum/topic/37584-street-legal-slicks/#findComment-565786 Share on other sites More sharing options...
Hi-Torque Member 24 Member For: 18y 9m 23d Posted 20/08/07 12:18 AM Share Posted 20/08/07 12:18 AM trevs said: thanks good read so does anybody have any of these fitted to their car if so which ones and what did you thinkI have ET streets in a 275/17 on the back of my XRT they grip great but no much good in the wet. Link to comment https://www.fordxr6turbo.com/forum/topic/37584-street-legal-slicks/#findComment-565819 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 1m 7d Gender: Male Location: @ my laptop Posted 21/08/07 01:03 AM Share Posted 21/08/07 01:03 AM American DOT approval is not recognised in australia, so a lot of people are using tyres they think are legal and they are not, although most coppers do not even realise this Link to comment https://www.fordxr6turbo.com/forum/topic/37584-street-legal-slicks/#findComment-566204 Share on other sites More sharing options...
trevs Member 781 Member For: 18y 2m 13d Gender: Male Location: balmain Posted 21/08/07 02:44 AM Author Share Posted 21/08/07 02:44 AM what about semi slicks Link to comment https://www.fordxr6turbo.com/forum/topic/37584-street-legal-slicks/#findComment-566210 Share on other sites More sharing options...
cooltint Member 686 Member For: 22y 2m 15d Gender: Male Location: Gold Coast QLD Posted 21/08/07 03:20 PM Share Posted 21/08/07 03:20 PM trevs said: what about semi slicksThat's what he's refering to, R Spec or semi slick are race tyres with DOT (Department of Transport) approval.Big AL Link to comment https://www.fordxr6turbo.com/forum/topic/37584-street-legal-slicks/#findComment-566506 Share on other sites More sharing options...
trevs Member 781 Member For: 18y 2m 13d Gender: Male Location: balmain Posted 21/08/07 04:54 PM Author Share Posted 21/08/07 04:54 PM so what is the best tyre I can put on my standard 17 inch rims that's legal under 500 bucks a tyre Link to comment https://www.fordxr6turbo.com/forum/topic/37584-street-legal-slicks/#findComment-566527 Share on other sites More sharing options...
cooltint Member 686 Member For: 22y 2m 15d Gender: Male Location: Gold Coast QLD Posted 22/08/07 12:36 PM Share Posted 22/08/07 12:36 PM trevs said: so what is the best tyre I can put on my standard 17 inch rims that's legal under 500 bucks a tyreGood question, I'm not entirely sure but I might suggest a call to the local transport inspector to ask what they know of the different laws regarding DOT approval between here and overseas. That would be a good start. Don't forget to let us all know what you find out though.Big AL Link to comment https://www.fordxr6turbo.com/forum/topic/37584-street-legal-slicks/#findComment-566808 Share on other sites More sharing options...
