trevs Member 781 Member For: 17y 9m 28d Gender: Male Location: balmain Posted 23/08/07 04:45 PM Author Share Posted 23/08/07 04:45 PM cheers dude ill check that tomorrow Link to comment Share on other sites More sharing options...
trevs Member 781 Member For: 17y 9m 28d Gender: Male Location: balmain Posted 24/08/07 04:37 PM Author Share Posted 24/08/07 04:37 PM checked the ground cable 0 ohms so that's not it even done a cold crank start so I could monitor it under load does anybody else have any ideas of what I should be looking for since ford are f*cking useless Link to comment Share on other sites More sharing options...
Sly_Bastard Member 72 Member For: 18y 1m 15d Gender: Male Location: Brissy Posted 25/08/07 01:28 AM Share Posted 25/08/07 01:28 AM checked the ground cable 0 ohms so that's not it even done a cold crank start so I could monitor it under load does anybody else have any ideas of what I should be looking for since ford are f*cking uselessDid you check the whole engine. Mine was fine on the top on the intake, but down near my sump it wasn't grounded properly. So you need to work your way around the whole engine :(If its not the engine, my guess would be the fuel pump or something to do with your fuel system by the sounds on it. But that's only a guess and there are so many possibilities. Link to comment Share on other sites More sharing options...
trevs Member 781 Member For: 17y 9m 28d Gender: Male Location: balmain Posted 25/08/07 07:14 AM Author Share Posted 25/08/07 07:14 AM nar didnt check the whole lot Link to comment Share on other sites More sharing options...
mr sti Member 5 Member For: 17y 8m 6d Posted 25/08/07 12:12 PM Share Posted 25/08/07 12:12 PM Earthing is a big prob when you start getting up in the higher horsepower there's alot of aftermarket kits for most big horsepower cars. I don't know if you remember but my car 's arlam used to come on while driving(eg the car would shut down at any speed) that was due to poor earthing perfect for a std car but when modded it caused problems. What I think you will find trev is your car like mine is not built to back bullsh*t high horsepower.Yes the car will make good power and the engine will handle it to a safe point but the whole car was designed to handle 190wkw not 300wkw it will take a little time to iron out little problems stick with it. I took my wrx from 94wkw to just over 220wkw and it took me over 6 months just to get all the little problems sorted with it .Building a fast car can take a week building a fast reliable car takes some time. Link to comment Share on other sites More sharing options...
trevs Member 781 Member For: 17y 9m 28d Gender: Male Location: balmain Posted 26/08/07 10:13 AM Author Share Posted 26/08/07 10:13 AM yeah I remember that think ill check my earths again tomorrow while im at work f*ck sh*t like this makes me mad Link to comment Share on other sites More sharing options...
